Budget (including currency): asd
Country: netherlands
Games, programs or workloads that it will be used for: mostly rainbow six siege
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): i have now a i5-10400 with 16gig of ram running at 2660 a 6650xt and 1,5 tb ssd. i ran a system bottleneck tester and saw that i had a hard ram bottleneck, so my question is shoul i upgrade to a 4200mhz ddr4 ram and keep my motherbord and my processor. Or shoul i spend 740 euro's for a new motherbord a ryzen5 7600 and ddr5 ram. what should i do?
https://linustechtips.com/topic/1590227-i-need-help/
To upgrade, or not to upgrade.
Only you can answer it.
If you really want a good platform, and a good cpu that can handle even a 4090, yes, go am5 7600/7700 and 2x16 6000mhz cl30 ram.
If you want to spend as little money as possible and only ram is bothering you, get like, a 2x16 kit, at 3200mhz cl16.
It'll last you for longer.
https://linustechtips.com/topic/1590227-i-need-help/#findComment-16581885
Bottleneck calculators aren't really trustworthy
What you should rather consider is
What's your FPS and stability (ie lows)?
What's the performance you want to achieve?
And asd isn't a value 😄
https://linustechtips.com/topic/1590227-i-need-help/#findComment-16581901
