Budget (including currency): 1000$
Country: IDN
Games, programs or workloads that it will be used for: Valorant, deadlock, black myth wukong
So I'm currently building a pc with 7600x and a 750w PSU. Now while searching for a second hand GPU, I find an AMD RX 6800xt and a RTX 3080 TI for the same price. I need some opinion on whether to get the 6800xt or the 3080 TI because from what i've seen from benchmark and reviews, 6800xt have the same/less performance with the 3080 TI while running more efficient. Which one do you think i should get?
https://linustechtips.com/topic/1588299-need-advice-for-gpu/
Not much of a difference in fps and perfomance (its like 10 fps at best) and since both are used the only question is how much you value RT. If you want and care alot about RT get the 3080 TI for sure if you dont mind it or use it liberally get whichever one is cheaper. But mind you it also does depend a lil on what games you play cause some games are more optimized for certain GPUs like starfield is for AMD GPUs
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1588299-need-advice-for-gpu/#findComment-16568195
yeah i think i'm leaning more towards the 6800xt especially because the power consumption is much more efficient than the rtx 3080 TI. I don't really use RT that much either because in high graphics settings, it's already beautiful enough :). Thank you for your opinion 😄 !
https://linustechtips.com/topic/1588299-need-advice-for-gpu/#findComment-16568196
