Budget (including currency): 750 euros
Country: Germany
Games, programs or workloads that it will be used for: Twinmotion
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I plan to use the PC mainly for Twinmotion. I plan to buy really soon. Would this build be sufficient?
https://de.pcpartpicker.com/user/Spacer_v2000/saved/bFJzZL
https://linustechtips.com/topic/1588233-build-for-twinmotion/
Country: Germany
https://de.pcpartpicker.com/list/gqz48Q
this is what I can recommend
I've met all the "high end requirements"
as per epic games
https://dev.epicgames.com/documentation/en-us/twinmotion/hardware-and-software-specifications-for-twinmotion
I'm not entirely familiar with what twinmotion is but what I saw was that it was VR rendering.
Intel CPUs tend to be better at that so I went with the 14400F instead of the 5700X.
https://linustechtips.com/topic/1588233-build-for-twinmotion/#findComment-16567544
Country: Germany
You might also want to consider buying a used GPU. for high end specs you need 12 gb of vram and a 20,000 bench score.
I know AMD is worse at rendering but you should look at the 6700 XT on local marketplaces like fb marketplace or look for a 6700 XT on German eBay.
https://linustechtips.com/topic/1588233-build-for-twinmotion/#findComment-16568331
