Wireless or wired connection?
Hello, Currently I am with Virgin Media a wifi provider in the Uk we are paying for 1GB Down and 500 Up. Current speed tests indicate I am getting 250 down and 120 up to my PC with other devices connected to the Hub. Hub Test has revealed that the hub is running at the speeds it should be, I am looking to increase the bandwidth to my PC but am wondering how, I am comfortable with running an ethernet connection to my PC.
My Pc is currently located on the second floor of my home and is connected wirelessly to my Wi-Fi router, current MB is a Asus PRIME B550M-A (WI-FI) Micro ATX AM4 Motherboard
Appreciate any suggestions.
https://linustechtips.com/topic/1587233-wireless-or-wired-connection/
wired wifi?
wifi means wireless. if you wire it, its not wifi.
because I get frustrated about this because of the implications:
Virgin media is an ISP, not your wifi provider, their job ends at your modem. the way you set up and control your LAN is NOT their job, they just offer additional services to do some of it for you, like a router that they control (as well as get you on that sweet router rental money). Ideally you should have your own router, its cheaper most of the time anyways then renting one.
To get the speeds you were promised, yes you need to have your LAN set up for it.  So yes, upgrading your router to wifi 7 and slotting in a higher end wifi card into one of your pcie slots for wifi 7. (or 6e)
The ideal is conduit to your PC of cat 5/6/6a which will get you the Gigabit (6a is the best, there are higher rated ones, but they have different plug standards). If you cant do that, then mocha is a choice, if you dont have coax going to your room, powerline also exists, but you need to make sure your router and your room are on the SAME phase.
1 minute ago, MRCW said:
Any advice on which type of cable to go for?
Cat 6. Already with plugs on each end to make it easy.
If it's gonna run on the outside of the house, run it in some sealed basic plastic piping.
First of all, are you sure that is indeed is your WiFi that is slowing you down? Have you ever down a speed test while being really close to the router?
Cat 6 is what you should go for for 1 Gbps+ bandwidth.
PLEASE MARK COMMENTS AS SOLUTION IF SATISFIED!!
bigger number better, makes me look cooler.
I mean, the board only has  Intel® Wi-Fi 6 AX200, you are never going to get 1 Gb on that without being in the same room as the router.
please note, I say only, but its a really good chip.
5 minutes ago, MRCW said:
thank you!
I maintained a 1GB ethernet connection with this specific cable...
https://www.amazon.com/gp/product/B00WD017BG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
There is a generation today that refers to internet access regardless of the connection medium as "wifi". Its unfortunate.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
