Gpu Temps on nr200p
2 minutes ago, Mohammed Abu Jayyab said:Hello!
So i recently ran some tests on my system to check if everything is alright temp/usage wise. So i booted up msi afterburner and ran warhammer 40k spacemarines 2. My cpu temps are superb, 56-62 degrees celsius (132-143 fahrenheit) my gpu temps however are questionable, im getting around 83-85 degrees celsius (181-185 fahrenheit) i am currently running two p12 120mm fans under it and tested it without but it did not do a difference. My question is then, should i get slim fans instead, should i deshroud or am i overreacting?
my cpu is an i5 12400f
my gpu is an hp oem 3070
Cooler is an arctic esports duo 34
83-85c is warm but still within safe limits for the 3070 GPU. My 980 Ti used to run that hot all the time.
You can try to make a custom fan curve to increase cooling a bit or increase the P12 fan's speed.
The temperatures are not dangerous however.
