My pc boots up then goes into automatic repair, Before this there was a burning smell and it powerd off I originally thought It was the gpu but I put it in a seccondery pc and it worked fine.
I have also tried new ram and that didn't work and whenever I boot it says automatic repair couldn't work and shows me a path to srttrail.txt file.
On a wim I put the boot ssd into another pc and it works fine it's only when In my pc it gets stuck into automatic repair.
Things tried.
New ram
New gpu
Cmos/bios reset
New boot drive
Rollback to backup
Automatic repair
Fresh windows 11 installation
Any help appreciated
https://linustechtips.com/topic/1586933-automatic-repair-stuck/
Burning smell should be a warning to not boot your PC until you find the source.
You smelled your PSU ? This is the first thing to check when burn components happen. If it's the PSU, then change it even it it works again. It has become a fire hazard.
https://linustechtips.com/topic/1586933-automatic-repair-stuck/#findComment-16556567
