Ok just wanted to sanity check my idea for a new pc my old one is from the early 2000…it hasn’t been on in years lol I play on an Xbox series x currently I might also wait until the new generation of gpu come out or maybe borrow a 3060 from a friend just to get it up don’t know yet lol
Ok
CPU Intel Core i9-14900KF 3.2 GHz
Gpu(maybe lol) Asus TUF GAMING GeForce RTX 4080 SUPER 16 GB
Storage Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME
TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory
 Motherboard MSI B760 GAMING PLUS WIFI ATX LGA1700
ARCTIC Liquid Freezer III 420 A-RGB 69.9 CFM Liquid CPU Cooler
Case NZXT H7 Flow (2024) ATX Mid Tower
Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (might go bigger just to future proof it a bit )
As well as 3 be quiet! Pure Wings 2 87 CFM 120 mm Fan
And a be quiet! Silent Wings Pro 4 97.41 CFM 140 mm Fan
all in all this is costing me around 3300 Canadian my budget is about 3000 to 3500
https://linustechtips.com/topic/1586614-first-pc-build/
7 minutes ago, Facemcshooty said:
Mostly gaming (rts and rpg probably quite a bit of flights similar to) but will probably mess around with editing and stuff like that on the side
Hello... I would wait until tomorrow when the new Core Ultra Series comes out. The 13th & 14th Gen Intel CPUs have serious issues that Destroy the CPU and there is no reversing the Damage. So I have 3 options for you. The first is a 12900K 12th Gen Build that has no issues. 2nd is the New Core Ultra i7 265K w/ Z890 Motherboard, the Core Ultra i7 265K has the same amount of Cores as the 14900K it has 20 Cores & 20 Threads. 3rd is a AMD 7800X3D Build.
You can take your pick and you decide. Feel free to ask me anything. I respond much faster on Discord: Wizardsnapper#2772 as I have it open 24/7.
I have been building PCs for over 30 years so if you have any questions please ask. For Future Communication I use Discord for much Faster Response Times as I have it open 24/7. I am also available if you need help before, during, or after the Build Process on Discord through Text,Voice, or Video Chat. I can be with you while you build your new PC if you need me to be. Here is my Discord: Wizardsnapper#2772
Intel Core Ultra 7 265K
CPU: Intel Core Ultra 7 265K 3.9 GHz 20-Core Processor  ($400.00)
CPU Cooler: Thermalright Frozen Notte ARGB 72.37 CFM Liquid CPU Cooler  ($93.84 @ Amazon Canada)
Motherboard: Asus TUF GAMING Z890-PLUS WIFI ATX LGA1851 Motherboard  ($439.99 @ Amazon Canada)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($142.99 @ Amazon Canada)
Storage: Samsung 990 Pro w/Heatsink 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($249.99 @ Amazon Canada)
Video Card: Gigabyte WINDFORCE V2 GeForce RTX 4080 SUPER 16 GB Video Card  ($1307.99 @ Amazon Canada)
Case: NZXT H6 Flow ATX Mid Tower Case  ($139.99 @ Amazon Canada)
Power Supply: NZXT C1200 1200 W 80+ Gold Certified Fully Modular ATX Power Supply  ($239.99 @ Amazon Canada)
Case Fan: Thermalright TL-C12C-S X3 66.17 CFM 120 mm Fans 3-Pack  ($20.90 @ Amazon Canada)
Case Fan: Thermalright TL-C14C-S 75.8 CFM 140 mm Fan  ($15.90 @ Amazon Canada)
Case Fan: Thermalright TL-C12C-S 66.17 CFM 120 mm Fan  ($11.29 @ Amazon Canada)
Total: $3078.77
Intel Core i9 12900K
CPU: Intel Core i9-12900K 3.2 GHz 16-Core Processor  ($416.89 @ Amazon Canada)
Motherboard: Gigabyte Z790 EAGLE AX ATX LGA1700 Motherboard  ($248.97 @ Amazon Canada)
Total: $2904.64
AMD AM4 5700X3D Build
CPU: AMD Ryzen 7 5700X3D 3 GHz 8-Core Processor  ($299.00 @ Amazon Canada)
Motherboard: MSI MAG B550 TOMAHAWK MAX WIFI ATX AM4 Motherboard  ($214.98 @ Amazon Canada)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($117.99 @ Amazon Canada)
Total: $2727.76
https://linustechtips.com/topic/1586614-first-pc-build/#findComment-16554211
Total: $3078.77
Total: $2904.64
Total: $2727.76
Thanks for the reply
I was under the impression that the 14 generation chips were updated to not spontaneously combust anymore lol
as for the new generation as to an my limited knowledge can see it’s generally a bad idea to get one at first they seem to need lots of updates and such for the first few months so you really don’t know what your getting until then and the motherboards seem seen very expensive lol
and something I should have mentioned the reason I went with a super big cooler is because the room I’m in normally gets 40 degrees c in the summer heat and the noise from the heat is something I’m trying to avoid but maybe bigger isn’t better I honestly don’t know
https://linustechtips.com/topic/1586614-first-pc-build/#findComment-16554960
Well then... I would go with the 12900K Build if you are really into Intel or the AMD Ryzen 5700X3D if you want a more Immersive Experience for Gaming and not even worry about the Newer Intel CPUs for a year or 2 if you really really want one but 13th & 14th Gen Intel is really bad right now and if you get one it's a waste of money because Intel is not Servicing them at all, no returns, exchanges, or refunds.
I know you said that you wanted a Big Cooler but the Thermalright Frozen Notte is a 360mm AIO Water Cooler and are MUCH BETTER at Cooling a CPU buy at least 20c. I've seen the Best Air Coolers on the Intel Core i9 14900K and see it go over 90c-110c, the AIO takes them down to about 75c-80c and that's the Hottest CPU there is. If you used the AIO on the 12900K or the 5700X3D then you could see Temps in the Range of 30c-50c while under Load.
Again, I'm always here to answer any questions. I really do respond much faster on my Discord: Wizardsnapper#2772 .
https://linustechtips.com/topic/1586614-first-pc-build/#findComment-16554973
