I have reinstalled Windows 8, 4 times now. I have soo many problems it is hard to even conceive. This time I formatted EVERYHTING, installed ONE driver, the chipset driver. Screen went black, then said no signal. I have now tried so many things I am almost certain I have a broken piece of hardware. Is it a broken GPU? Thanks for any help, I am starting to freak.
Previous problems:
"Display driver has stopped working and has been recovered" (many many times)
Visual glitches
Black screening during gaming
Error message + plus forced Windows repair and restore
BTW:
PC is 2 days old and consists of an i5-4670k, GTX 770, and Fatal1ty z87 Killer motherboard. No overclocks.
https://linustechtips.com/topic/158651-problems-after-fresh-install-is-it-hardware/
Good luck!
Well I did this and when I tried to install the VGA driver, it said a newer version is already installed. ????? I just formatted everything expect "unallocated space" because it couldn't be formatted. There should not be any driver on my computer! Can the MOBO store a driver? How on earth is there a driver already installed...
What do you mean by everything? How many drives do you have installed?
I suggest you only connect the drive that you want to install windows on if you haven't already and format that when you install windows.
Aah, good idea. Also, once I have removed the GPU, is there any stress test that I can run on the computer?
Benchmarking will only test the stability of your hardware. If you have no driver issues, you shouldn't need to test your components.
But when I test my Overclocking I have used Prime95.
