i just got a taste of Lian Li 011 Dynamic Mini and i love the dual Chamber, however i do miss how u took off the panel off old mid Towers With just sliding them and put two thumb screws on the side one up and the other Down.
what i am looking for is a dual Chamber mid Tower however the side panel can be taken off and Works just like the normal mid Towers, the push and put two thumb screw one at top and bottom type. perferably 43 cm in height however any size i can work around
https://linustechtips.com/topic/1585455-need-help-finding-a-cool-pc-case/
Why does it have to specifically need the specific accessibility interface, instead the ones the Dual-chamber cases have normally?
current PC:
PC configs I used before:
it's more that i am curious if such a pc case exist? i have no problem about using a normal dual chamber but for example i don't like the glass walls, i perfer those plaxi glass/plastic windows on the normal mid towers. reason i made this topic if somebody know something i don't know
Not sure about sliding.
I know about Dual Chambers having "frames" where it's not all clear glass and there's black, either black glass or something that makes a frame.
I don't know cases in detail, I know specs, qualities to an extent and that's about it.
But I've noticed NZXT H6 flow has screw at the back, not sure if it's just one, it doesn't slide it pans out, but it's got the thumb screw at the backside, rather than the circular screws that are embedded at each corner of the glass.
current PC:
