Mayhems is pretty good.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/158512-selecting-a-coolant/#findComment-2112714
TBH the best coolant is just distilled water with a silver kill coil in it (there has been a lot of testing done on this can link if needs be). However I assume you want dye in it so mayhems or EK's coolant would both work, I do not think there would be a huge difference between the two so whatever you can get cheaper/easier.
https://linustechtips.com/topic/158512-selecting-a-coolant/#findComment-2114075
I agree with @D3LTA9. Some of these fluids will eventually gunk up your system and nothing is better than just plain distilled water with a kill coil as a biocide. I have experience with mayhem and have had no problems with their dyes. Good luck!
https://linustechtips.com/topic/158512-selecting-a-coolant/#findComment-2114392
Both my brother and I use EK EKoolant.
They are basicly destilled water in different colors with Biocides and anti corosiion additives premixed.
http://goo.gl/TWPIyt
We have used them for a year now, and have never had an issue with this coolant.
I opted out of the kill coils since after a while they will start to corode.
And if they arent replaced they might start sending particles around your loop.
But that isnt untill you have had them for a good while though.
an example of this would be: http://goo.gl/hKQwK7
This is an extreme example though.
https://linustechtips.com/topic/158512-selecting-a-coolant/#findComment-2116882
Using Feser 1 Advanced here....clear Coolant though.....cant beat $12 / bottle....change it out every 6 months.
The gunking up of Blocks....from what I've read (tons of research on the Subject), is caused by Plasticizers within the tubing....not the Coolant itself.
If you're providing 6 month - 12 month maintenance to your Loop, cant see this being an issue.
3930K - 4.85Ghz w EK Supremacy | RIVE w Photon 170 D5 Vario / Res Combo | 16GB 1866 Doms | Evga GTX 780Ti SC SLi w EK Full WB's| AX 1.2 kW | 900D - 1 x RX480 1 x EX360 & 1 x EX240 Rads w Noctua NF F & Corsair SP "Push" | W7 HP x64 | MK11: P25,113 http://www.3dmark.com/3dm11/7499603 | Firestrike: 19,576 http://www.3dmark.com/fs/1177627
https://linustechtips.com/topic/158512-selecting-a-coolant/#findComment-2119317
