1 minute ago, tkitch said:
Try drinking some water, have a snack, and then take a nap?
If you're talking about computer memory, you need to tell us way more about the issue / your system.
I can send a link to my pc stuff from pcspecialists if that helps you
https://linustechtips.com/topic/1584820-help-ples/#findComment-16540440
https://pcpartpicker.com/list/28g37R
That's a link to my build
https://linustechtips.com/topic/1584820-help-ples/#findComment-16540444
22 minutes ago, tkitch said:
try one stick at a time, and then in each of the slots.
If one stick doesn't work, try the second stick.
If none work:
Try reseating the CPU and then test RAM again
If that doesn't work, it's time to start RMAing parts
How would I reset the CPU without taking it out? Or is that not possible?
https://linustechtips.com/topic/1584820-help-ples/#findComment-16540463
