I am thinking of swapping my pc case to a hyte y70 and getting new Corsair ql fans and don’t know how many I would need. I also have a Deepcool ls720 cooler that I would want to switch the fans from the stock Deepcool ones to the Corsair ones and don’t know if that is possible. My current build is listed below.
https://linustechtips.com/topic/1583332-case-question/
You can swap the fans on the deepcool AIO to any 120x25mm fans. If you want better cpu temps, you could go for thicker fans like Antec's 120x30mm if you want, but those dont have any lighting at all. The 7800x3d is a cool running chip overall so there is no thermal reason to swap our the stock fans, but if you like the look of the corsair QL fans you can swap those on to this cooler. The Hyte Y70 will be a massive improvement in airflow over your thermaltake case you have now. Use the side or top mount for your radiator but ensure you mount the radiator tubes down when you are using the side mount, if the tubes dont reach, use the top mount. This will improve the longevity of your aio and its noise characteristics.
Hope this helps and feel free to ask any more questions!
https://linustechtips.com/topic/1583332-case-question/#findComment-16526871
swapping case requires the graphics card and power supply to come out separately, as well as any hard drives, but the motherboard can keep the CPU cooler, ram, CPU, and any M.2 drives installed while you move
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1583332-case-question/#findComment-16527116
46 minutes ago, Jacob Rotkowitz said:
I want to swap cases and don’t know if it is difficult. I built my pc myself and don’t like the case anymore. What order is best to swap cases? I am getting the Hyte y70 with 10 new fans also
How difficult was building the PC for you?  It's just taking it back apart, then doing the exact same thing you already did once.
We can't know how difficult this is for you, but you have all the info you need to make that call for yourself.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1583332-case-question/#findComment-16527136
I am swapping cases soon and wanted to know what order is best to take things out the old case and to put in the new. Should I pre install all the new fans I am getting or do that after the motherboard is in. I am getting the Hyte y70 and 10 Lian li fans and don’t know what order to do anything in
https://linustechtips.com/topic/1583332-case-question/#findComment-16527263
There is no right answer to this. As sometimes the fans will be in the way of installing the motherboard. So many times you'll want to install the motherboard first. However other times you'll want to run wires behind the motherboard (carefully, don't pinch anything).
My general rule of thumb is to go with the motherboard first, then move to the fans. However as I mentioned, don't make this a hard rule, as you may need to change it as you go.
https://linustechtips.com/topic/1583332-case-question/#findComment-16527270
the only reason to install all the fans before the motherboard is when  the motherboard and stuff is on a test bench and is being tested / u install windows on it outside the case. then u can save some time and do fans, RGB stuff and other wire-jobs
https://linustechtips.com/topic/1583332-case-question/#findComment-16527355
When I built my niece's PC, I didn't notice how little space there was above the mobo. I ended up having it mostly put together but couldn't get the top fans in. ARGH!!! I had to remove so many parts! What a pain!
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1583332-case-question/#findComment-16527414
I dont know that is the most comfortable way for me
Find it to be way easier for cable management
but again, there is no good way to do it
https://linustechtips.com/topic/1583332-case-question/#findComment-16527433
It mostly depends on the parts you have, what's connected to the case, and differences between the 2 cases, like dimensions.
https://linustechtips.com/topic/1583332-case-question/#findComment-16527496
Kind of a bizarre question to ask. Did you actually assemble your own PC? Think of that, but in reverse. In fact, it's easier because undoing cable routing is easier and faster than setting it up.
It may be easier or harder to assemble the new PC depending if the new case is easier or harder to assemble in compared to the previous PC?
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
https://linustechtips.com/topic/1583332-case-question/#findComment-16527616
He says he did, so it's an odd question.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1583332-case-question/#findComment-16527657
On 9/21/2024 at 11:43 AM, Jacob Rotkowitz said:
How many 120mm fans does the hyte y70 fit besides the aio
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1583332-case-question/#findComment-16530723
