Hey guys! I'm planning a build for within the next few months. I built my last PC around 2014, so I'm a bit out of touch when it comes to modern parts. That being said, I made this parts list, and I'd love to hear your thoughts!
https://pcpartpicker.com/list/JqDm4M
Country: United States
Games, programs or workloads that it will be used for: 3D Gaming, Game Development, 3D modeling, video rendering
Let me know what you think! Thanks!
https://linustechtips.com/topic/1582848-thoughts-on-my-build/
Do you have a budget?  Do you do the productivity for a job, or just for fun?
Your AIO is overpriced by 200%.   The motherboard should be around $200.
RAM should be 6000CL30 for Ryzen.
GPU is way overpriced even for being White, and underpowered for the 1440p 240Hz monitor you chose.  With your budget, you can fit a 4080 Super in there.
So you're basically $800-$1000 overspend, IMO.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1582848-thoughts-on-my-build/#findComment-16522746
Completely agreed, unless your doing super high workloads that need all 16 cores, you should definitely go with a 7800x3d or 7900 equivalent
https://linustechtips.com/topic/1582848-thoughts-on-my-build/#findComment-16522752
I'm an indie developer, but it isn't my main gig. I don't really have a budget; I'm planning to save up for a few months to build this.
Thanks for all the tips! With this advice, I was somehow able to reduce the overall cost by $100 and still have room for a 4080 Super. I also decided to go with just a 1TB SSD to start off with, knowing that I can expand later. My only problem with this list is that my cpu fan doesn't really fit the aesthetic, do you have any recommendations for the white theme I'm going for?
Here's my new list: https://pcpartpicker.com/list/Kvbd34
https://linustechtips.com/topic/1582848-thoughts-on-my-build/#findComment-16522960
Yes, the Peerless Assassin performs the same as the Noctua.... and that CPU is pretty efficient as well...
Amazon.com: Thermalright Peerless Assassin 140 White CPU Air Cooler, 6 Heat Pipes, Dual PWM Fans and Double Towers,158mm High CPU Cooling with Top Cover,forAM4/AM5&Intel LGA 1851/1700/1150/1151/1200 : Electronics
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1582848-thoughts-on-my-build/#findComment-16523010
