Hello, need bit of help as not getting wth is this has anyone seen this before
Few times i have gotten this weird artifact while stress testing
RanTest with 3d Mark & Cinebench some times i have gotten this after rebooting the PC its okay,
its very random, run quite few 3D Mark and Cinebench tests and all is okay.
No problem on daily driving or gaming or even streaming.
Drivers have already been updated.
Ran Cinebench and 3d Mark yesterday and saw this video first time seeing this never seen this before
Video - https://drive.google.com/file/d/17WAyN69qjXt5_1Y191G1bbao4hrIIGwM/view?usp=drive_link
Specs are Ryzen 9 5900x
RTX 4080 Super strix
850Watt Corsair RM psu
no OW of any kind
have set -30 in Curve Optimizer but thats been for years.
rest of the system is same only cards changed 3080 and 4080 cards.
The Blurry block at on the left side of monitor always happens on the same location and on Samsung Odyssey G8 Neo, other monitors look and work okay.
https://linustechtips.com/topic/1582132-weird-artifact-while-running-benchmarks/
Your google drive requires permission to access. Upload your vids to youtube and set them to unlisted, Upload pictures here on the forum.
Video artifacts can be caused either by the monitor, the video cable or the most likely suspect... the GPU. Could also be the motherboard's PCI-e slot.
Considering you just changed the GPU (if I understand you correctly) while the rest was functional before... My guess is you got a defective GPU. Return that ASAP and get another one.
It is a bit weird if the issue is only on a single monitor and always in the same spot.
You could try changing the video cable between two monitors to see if the issue follows it.
Latest Bios? Tried without the negative curve offset?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
no OW of any kind
You could probably eliminate a system's hardware fault lowering the GPU memory clock or the max TDP of the card. That's usually not how VRAM stability artifacting looks, but I haven't seen it while using display stream compression with modern hardware.
I'd suspect a bad cable or connection to the monitor, looks like an error with DSC. Are you using HDMI or DP to the display?
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
I have updated the Link please check now.
I had this GPU since January and ran benchmark tests multiple times never had problem
The Lateast thing is the Monitor Samsung ODYSSEY Neo G8 and have only seen this happening on this monitor. Will try Checking the cable
PRIME X570-PRO BIOS 5013
Version 5013
16.31 MB
2024/04/03
"Update AGESA version to ComboV2PI 1.2.0.Ca.
Fix AMD processor vulnerabilities security."
no new update in months
I have set Power Target to 95 % and rest is on default with Aggresive fan curve.
Never had any issues with gaming.
as few said it might be cable.
I have swapped the cables on both monitors will test later today lets see, fingers crossed just issue with cable nothing bigger.
If it only has this issue on your G8 Neo and you've tried multiple displays separately it's either the monitor itself or the cable you are using. Swap the cable first. If it still shows I'd test on a completely separate monitor, make sure when you're testing that you only have the monitor you want to test plugged into the computer, not multiple displays. One monitor, one cable. Test individually.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Check if there is a firmware update for the monitor.
1 hour ago, Shahzadasweet said:
Thanks for all the suggestions guys.
I think its the HDMI cable.
i have swapped over the HDMI cable from my main monitor to 2nd 4k monitor and ran all the tests on Cinebench and 3d Mark no issues.
I wouldn't run HDMI on the Neo G8. DP with DSC has given me zero issues with the display, its been my main display since its release date.
HDMI could go higher bit depth colours compared to DP so was using that and weirdly its been on for months with no issues.
but i have switched to DP will try to test and see if its actually cable issue
