Im having some audio crackling issues, already tried doing a clean install
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for  0:01:26  (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name:                                        s-PC
OS version:                                           Windows 11, 10.0, version 2009, build: 22631 (x64)
Hardware:                                             To Be Filled By O.E.M., To Be Filled By O.E.M.
BIOS:                                                 P10.31
CPU:                                                  AuthenticAMD AMD Ryzen 7 5700X3D 8-Core Processor
Logical processors:                                   16
Processor groups:                                     1
Processor group size:                                 16
RAM:                                                  32692 MB total
CPU SPEED
Reported CPU speed (WMI):                             3001 MHz
Reported CPU speed (registry):                        2994 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs):   192.40
Average measured interrupt to process latency (µs):   4.694472
Highest measured interrupt to DPC latency (µs):       117.70
Average measured interrupt to DPC latency (µs):       0.983254
 REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs):              955.490982
Driver with highest ISR routine execution time:       Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%):          0.197491
Driver with highest ISR total time:                   Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%)                          0.198208
ISR count (execution time <250 µs):                   1140684
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-1000 µs):               8
ISR count (execution time 1000-2000 µs):              0
ISR count (execution time 2000-4000 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs):              31636.843687
Driver with highest DPC routine execution time:       storahci.sys - MS AHCI Storport Miniport Driver, Microsoft Corporation
Highest reported total DPC routine time (%):          0.070061
Driver with highest DPC total execution time:         storahci.sys - MS AHCI Storport Miniport Driver, Microsoft Corporation
Total time spent in DPCs (%)                          0.192365
DPC count (execution time <250 µs):                   876228
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-10000 µs):              21
DPC count (execution time 1000-2000 µs):              1
DPC count (execution time 2000-4000 µs):              0
DPC count (execution time >=4000 µs):                 33
 REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count:                 msmpeng.exe
Total number of hard pagefaults                       216
Hard pagefault count of hardest hit process:          111
Number of processes hit:                              15
 PER CPU DATA
CPU 0 Interrupt cycle time (s):                       0.492887
CPU 0 ISR highest execution time (µs):                0.0
CPU 0 ISR total execution time (s):                   0.0
CPU 0 ISR count:                                      0
CPU 0 DPC highest execution time (µs):                20.651303
CPU 0 DPC total execution time (s):                   0.021087
CPU 0 DPC count:                                      13681
CPU 1 Interrupt cycle time (s):                       7.344342
CPU 1 ISR highest execution time (µs):                654.258517
CPU 1 ISR total execution time (s):                   2.635503
CPU 1 ISR count:                                      801663
CPU 1 DPC highest execution time (µs):                31636.843687
CPU 1 DPC total execution time (s):                   2.628125
CPU 1 DPC count:                                      855743
CPU 2 Interrupt cycle time (s):                       0.428465
CPU 2 ISR highest execution time (µs):                0.0
CPU 2 ISR total execution time (s):                   0.0
CPU 2 ISR count:                                      0
CPU 2 DPC highest execution time (µs):                35.280561
CPU 2 DPC total execution time (s):                   0.003792
CPU 2 DPC count:                                      1271
CPU 3 Interrupt cycle time (s):                       0.349919
CPU 3 ISR highest execution time (µs):                0.0
CPU 3 ISR total execution time (s):                   0.0
CPU 3 ISR count:                                      0
CPU 3 DPC highest execution time (µs):                28.727455
CPU 3 DPC total execution time (s):                   0.001122
CPU 3 DPC count:                                      463
CPU 4 Interrupt cycle time (s):                       0.432328
CPU 4 ISR highest execution time (µs):                0.0
CPU 4 ISR total execution time (s):                   0.0
CPU 4 ISR count:                                      0
CPU 4 DPC highest execution time (µs):                18.316633
CPU 4 DPC total execution time (s):                   0.003086
CPU 4 DPC count:                                      1037
CPU 5 Interrupt cycle time (s):                       0.374498
CPU 5 ISR highest execution time (µs):                0.0
CPU 5 ISR total execution time (s):                   0.0
CPU 5 ISR count:                                      0
CPU 5 DPC highest execution time (µs):                30.591182
CPU 5 DPC total execution time (s):                   0.000904
CPU 5 DPC count:                                      326
CPU 6 Interrupt cycle time (s):                       0.372999
CPU 6 ISR highest execution time (µs):                0.0
CPU 6 ISR total execution time (s):                   0.0
CPU 6 ISR count:                                      0
CPU 6 DPC highest execution time (µs):                18.136273
CPU 6 DPC total execution time (s):                   0.001794
CPU 6 DPC count:                                      546
CPU 7 Interrupt cycle time (s):                       0.334339
CPU 7 ISR highest execution time (µs):                0.0
CPU 7 ISR total execution time (s):                   0.0
CPU 7 ISR count:                                      0
CPU 7 DPC highest execution time (µs):                11.833667
CPU 7 DPC total execution time (s):                   0.000996
CPU 7 DPC count:                                      330
CPU 8 Interrupt cycle time (s):                       0.328209
CPU 8 ISR highest execution time (µs):                0.0
CPU 8 ISR total execution time (s):                   0.0
CPU 8 ISR count:                                      0
CPU 8 DPC highest execution time (µs):                20.551102
CPU 8 DPC total execution time (s):                   0.000777
CPU 8 DPC count:                                      233
CPU 9 Interrupt cycle time (s):                       0.299338
CPU 9 ISR highest execution time (µs):                0.0
CPU 9 ISR total execution time (s):                   0.0
CPU 9 ISR count:                                      0
CPU 9 DPC highest execution time (µs):                10.05010
CPU 9 DPC total execution time (s):                   0.000521
CPU 9 DPC count:                                      153
CPU 10 Interrupt cycle time (s):                       0.298831
CPU 10 ISR highest execution time (µs):                0.0
CPU 10 ISR total execution time (s):                   0.0
CPU 10 ISR count:                                      0
CPU 10 DPC highest execution time (µs):                14.569138
CPU 10 DPC total execution time (s):                   0.000518
CPU 10 DPC count:                                      133
CPU 11 Interrupt cycle time (s):                       0.283475
CPU 11 ISR highest execution time (µs):                0.0
CPU 11 ISR total execution time (s):                   0.0
CPU 11 ISR count:                                      0
CPU 11 DPC highest execution time (µs):                28.186373
CPU 11 DPC total execution time (s):                   0.000256
CPU 11 DPC count:                                      69
CPU 12 Interrupt cycle time (s):                       0.506640
CPU 12 ISR highest execution time (µs):                179.418838
CPU 12 ISR total execution time (s):                   0.085235
CPU 12 ISR count:                                      258984
CPU 12 DPC highest execution time (µs):                16.402806
CPU 12 DPC total execution time (s):                   0.003878
CPU 12 DPC count:                                      1459
CPU 13 Interrupt cycle time (s):                       0.311730
CPU 13 ISR highest execution time (µs):                13.386774
CPU 13 ISR total execution time (s):                   0.001988
CPU 13 ISR count:                                      5113
CPU 13 DPC highest execution time (µs):                11.693387
CPU 13 DPC total execution time (s):                   0.000306
CPU 13 DPC count:                                      107
CPU 14 Interrupt cycle time (s):                       0.359608
CPU 14 ISR highest execution time (µs):                14.278557
CPU 14 ISR total execution time (s):                   0.012799
CPU 14 ISR count:                                      35646
CPU 14 DPC highest execution time (µs):                136.082164
CPU 14 DPC total execution time (s):                   0.001894
CPU 14 DPC count:                                      550
CPU 15 Interrupt cycle time (s):                       0.374159
CPU 15 ISR highest execution time (µs):                955.490982
CPU 15 ISR total execution time (s):                   0.015096
CPU 15 ISR count:                                      39286
CPU 15 DPC highest execution time (µs):                45.290581
CPU 15 DPC total execution time (s):                   0.000481
CPU 15 DPC count:                                      182
https://linustechtips.com/topic/1581538-audio-crackling/
