Hey, I was wondering if anyone can provide a good recommendation for a Z87 or Z97 motherboard, and list there reason why, also my budget is around $200, location in Canada.
Will you be overclocking?
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
are you not going to answer? @airking95
I wouldn't recommend anything without knowing a bit more perspective on what you want & what you need.
Forgive me if I am out of your budget, I am not familiar with Canadian prices.
Personally, I would go for something like:
Z97 UD3H/UD5H  As they are quality motherboards, and have been for quite a while (since LGA took over at Intel). If they fit your budget and colour scheme, go for it.
Z97 WS is a great board from asus. I run teh WS series, and while I know it is above your budget, it is the most compatible board on the market hands down.
Z97 Extreme 4. I was far from happy with my Z77E4, but I would be willing to give it a try again. Their tech support needs some work though (and my case was a really specialized incident. We had a power failure during flashing the BIOS that cause the board to not POST at all. ASrock was willing to ship me the BIOS chip, and that was the only option, for like $10. I understand that there are people happy with working with those little chips, but I was not. I was more than willing to pay more for them to install the chip for me. But it was not even an Option. That pissed me off. (not to say that it took $20, the board, the chip and 5 minutes to get the local computer shop to install it.).
Desktop <dead?>
P8P67-WS/Z77 Extreme4/H61DE-S3. 4x4 Samsung 1600MHz/1x8GB Gskill 1866MHzC9. 750W OCZ ZT/750w Corsair CX. GTX480/Sapphire HD7950 1.05GHz (OC). Adata SP600 256GB x2/SSG 830 128GB/1TB Hatachi Deskstar/3TB Seagate. Windows XP/7Pro, Windows 10 on Test drive. FreeBSD and Fedora on liveboot USB3 drives.
Laptop <Works Beyond Spec>
HP-DM3. Pentium U5400. 2x4GB DDR3 1600MHz (Samsung iirc). Intel HD. 512GB SSD. 8TB USB drive (Western Digital). Coil Wine!!!!!! (Is that a spec?).
here is a good no frils mobo that does every thing you will need, but may lack in audio, but with enough left for a amp or dac
http://ca.pcpartpicker.com/part/msi-motherboard-z97g55sli
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
I would recommend a msi z97 gaming 5 or 7 or and Asus z97 plus and up
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
No worries, they are within my budget, and I would go for the Z97 UD3H/UD5H, only problem is that its not the colour scheme I was going for, I was more thinking towards a blue/white or red/white colour scheme.
As for the Z97 WS it does seem like a great board, but the aesthetics of it are making me think twice about it.
Z87 seems like the go to chipset versus Z97.
http://ca.pcpartpicker.com/part/msi-motherboard-z87g45gaming
It would always be easier to choose your board first and then your colour scheme based on the board, but I understand.   Maybe look at the Asus gaming series, like the Maximus VII Hero.
The Z97 Extreme 4 http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157503 is blue and would fit your theme. They als have a gamer board that is red  http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157505 .
Gigabyte has the z97 g1.sniper http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128706 and gaming 5 http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128709 that would fit a red colour scheme.
Desktop <dead?>
