Laptop extreme high temps
Go to solution Solved by Average Nerd,
It's normal for gaming laptops to run really hot, a way to reduce temps at least a bit is to raise the back of the laptop up so it sits at an angle and has better airflow, or to use a laptop cooling pad.
So basically I am very concerned about my Laptop that it will die in the next couple of months/years becuase it raises to very high temperatures everytime I play a game or do a heavy task. And now I wanted to ask in this forum if somebody knows how to cool it better or has any other tips. The first screenshot is from Overwatch today. The first three rows are MSI Afterburner and everything below are the temps of my CPU cores measured with HWInfo. My Laptop is a Lenovo Thinkbook 16p G4 IRH with a Intel Core I7 13700H and a RTX 4060. The other screenshot is from HWinfo and are the highest Temps I had during my Gaming session. I also apologize for my english because its not my Mothers Tounge. Please Help, thank you.image.png.e8f0f056a808f4f283c58aee29a24e1f.pngScreenshot2024-08-17155721.png.352a9c154e77ddcaf21185f153ef499d.png
https://linustechtips.com/topic/1579844-laptop-extreme-high-temps/
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
