First PC build
Solved by MiszS,
Not that bad, but you can improve a few things. Firstly you don't need a 7900X3D, in fact it's worse than a 7800X3D for gaming, so just get that. You also don't need an x670E motherboard, a B650 one would be just fine. You don't need a 1000W PSU with your setup, and with the saved money you can get a better GPU. I'm also assuming You chose the ram because it looks good, but you can also save like €30 with a different kit.
https://de.pcpartpicker.com/list/LFHmbL
