I have an Akko 3098B Multi Modes for 2 years now, and it has been glitchy for the last 1.5 years or so. The problem is that some keys are double-clicking, especially around the "WASD" region and a few keys at the num pads. I occasionally take out the switch to blow on it, and it works for a week or so, but the problem still occurs after. And I have tried replacing the switch itself and to no avail.
Does anyone have the same keyboard as mine and have these issues? And do you guys have any solution to permanently fix it as I don't want to replace this keyboard.
Any help will be appreciated!
https://linustechtips.com/topic/1578793-need-help-for-keyboard/
