H5 Flow GPU Clearance
Go to solution Solved by TatamiMatt,
11 minutes ago, ByteAtATime said:
Hey all, I'm looking at the H5 Flow (RGB) for my case. I want to get a 7900 GRE, but I'm not sure how big it can get. On the website alone, it lists two different values (400mm in the card, and 365mm in the specifications).
For safety, I'm taking the smaller value. Does this number include the width of the fans? My fans are 26mm in width, so does that mean my GPU has to be under 339mm?
Lastly, what is a good tolerance amount to have? Is a 335mm GPU (with 4mm tolerance) fine, or is it too large?
TYIA!
If a 335mm GPU is fine to fit in the case then then only issue youll have is with a powercolour red devil, all other cards are under this length
however, you wont even have issue with this as you have 365mm of clearance, as the fans do not affect this
Here is the case without fans:
And with fans, they are in their own seperate section
TYIA!
https://linustechtips.com/topic/1578104-h5-flow-gpu-clearance/
TYIA!
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1578104-h5-flow-gpu-clearance/#findComment-16480440
Yes, my question is how the calculation works and whether a 335mm GPU will actually fit.
https://linustechtips.com/topic/1578104-h5-flow-gpu-clearance/#findComment-16480441
Check my original reply again, was mid edit when you replied
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1578104-h5-flow-gpu-clearance/#findComment-16480442
TYIA!
Your fans is 25mm fans, they are mounted in the front, so they take no space, like shown here:
The clearance without a radiator installed is 365mm, so anything under that is ok. You can get a radiator up to 30mm in and still have 335mm.  A guy here clams to have squeezed in a 4090 x trio (337mm in lenght) with a z63 kraken (30mm radiator) :
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1578104-h5-flow-gpu-clearance/#findComment-16480444
