Download GParted Live ISO. Use Rufus to format the downloaded iso onto a USB stick.
When booting into GParted you can just keep pressing Enter at each prompt, this is of course you are using an ANSI Keyboard (USA) and English as your language.
When in GParted can you see the drive (click dropdown top right)
Hermit Rolling Build & Datacentre Colocation
Level 2 Support  |  Datacentre NetOps |  IT consulting  |  Entrepreneur
No help vampires, drive-by posters, or one-post wonders — I believe in mutual effort and learning.
https://linustechtips.com/topic/1578036-help-with-m2/#findComment-16479817
