Budget (including currency): 1500 EUR
Country: Lithuania
Games, programs or workloads that it will be used for: Mostly will be focused on 3D & 2D animations, drawing, 4K video editing. Occasional gaming like Apex, Hades, FF series. Mostly using Switch.
Other details: only completed case is needed. I see since PC part picker doesn't support my country (of course) I would be using that as my benchmark to check for reference and to know on what parts I should to focus more.
https://linustechtips.com/topic/1577636-build-for-work-and-games/
I don't know pricing but i will do my best.
For starting point , CPU should be i7 or ryzen 7 for you to edit in 4k.
2d animations is not that problem so i will be skipping it.
For 3d animation I will suggest team green nvidia rather than amd. For a long time they are more reliable in modeling etc.
Ryzen 7/i7 should be helpful at rendering these outputs as well (depending on renderer - some renderer use gpu)
Games shouldn't be issue here since rest of the system can hold up.
I will write down some parts. Can you tell me pricing in usd or euro cost in your country.
Ryzen 7 7800x3d
x670-p wifi msi ddr5 board
Kingston Fury Beast 32 GB (2x16) 6000 mhz
phanteks p500a case (if you dont like how it looks tell me)
thermalright phantom spirit 120 se / thermalright peerless assassin 120 se
RTX 4070 Ti SUPER
Corsair RMe 750w
Samsung 980 pro/evo (pro is faster but more expensive - be sure it is without cooler)
if you cant any of these parts just tell me i will look for alternative. Tell me your thoughts as well.
how its goin mate ? hope my post helps. Maybe drop a like or follow ? >w<
no ? i guessed that 😄
Completely agree but stick with Ryzen. Intel's recent chips have been blue screening lately and that's a risk I wouldn't want you taking.
Don't sleep on sleeper PCs
Country: Lithuania
Total: €1514,30
Board - €151.99
https://www.skytech.lt/pro-b650s-wifi-msi-pro-b650s-wifi-processor-family-amd-processor-socket-am5-ddr5-p-685122.html
CPU - €232.29
https://www.skytech.lt/100000000592-amd-ryzen-7700-procesorius-ghz-negamyklineje-pakuoteje-priedu-p-690612.html
Cooler - €49.19
https://www.skytech.lt/rag620bknnmng1-deepcool-ag620-black-intel-amd-cpu-air-cooler-p-607800.html
RAM - €110.39
https://www.skytech.lt/ax5u6000c3016gdtlabbk-adata-xpg-lancer-blade-ddr5-32gb-2x16gb-dimm-6000mhz-30404-p-686195.html
SSD - €130.19
https://www.skytech.lt/p400p2tbm28h-patriot-p400-2tb-2280-pcie-gen4-ssd-p-624217.html
GPU - €656.00
https://www.skytech.lt/vcg4070s12dfxpb1o-pny-geforce-rtx-4070-super-12gb-nvidia-gddr6x-p-694751.html
PSU - €108.79
https://www.skytech.lt/mag-a750gl-pcie5-msi-mag-a750gl-pcie5-750w-plus-gold-p-656654.html
Rear exhaust fan for case down below - €5.29
https://www.skytech.lt/acfan00120a-case-fan-120mmacfan00120a-arctic-p-706425.html
Case - €70.00
https://www.skytech.lt/fdcfoc2a01-fractal-design-focus-side-window-black-clear-tint-midi-tower-power-su-p-619333.html
https://www.fractal-design.com/products/cases/focus/focus-2/black-tg-clear-tint/
Thanks everybody for the lists. That nzxt case in @BeastyB314 list is really nice, and more expensive of course. @Why_Me thats really helpful with links to local dealer. I was planing using them. @cekcons all parts were able to find locally except the case. All phanteks cases are available, except that one. I already see that will have to go over the budget lol.
