So I have a Ryzen 5 3600 with a gtx 1050 ti gpu and I'm going to upgrade my gpu but I don't know which one to choose,  XFX Radeon RX 7600 Speedster SWFT210 Core Gaming 8GB GDDR6 (319,90€) or a MSI GeForce RTX 4060 Ventus 2X Black 8G OC DLSS3 (324,90€).
Would appreciate help with choosing because I'm new to this and want really to have better fps.
https://linustechtips.com/topic/1577554-need-help-in-upgrade/
The RTX 4060 hands down IMO. The 4060 will be more power efficient, let you use some raytracing and you get DLSS. Aside from that I think the 4060 is faster on average but in some games with 7600 has an advantage. With that said many people will pick the 7600 just to join the Radeon fan club.
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16475816
I am kinda biased towards AMD, but the 4060 is a better choice among those 2. That said, you will still get way better value just buying used, you can get a 6800 for around the same price if you look for a bit, and it destroys both of those cards in performance
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16475838
What games?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16475857
For 300, can you grab a 6750xt?
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16475882
Elden Ring, Red Dead Redemption, Palworld and Monster Hunter World
aight, those are GPU intensive,
It doesn't fit in my case unfortunately
6700xt?
current PC:
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16475965
1 minute ago, AlexF99 said:
well can't find in sites I know for like the price the two gpu's I mentioned, it's always much more
Can you share with use the sites you know?
If we know where you're buying from, we can recommend what is available to you.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16475977
what country?
current PC:
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16475981
1 hour ago, podkall said:
what country?
I'm from Portugal these are the sites I use and these are the most trustwhorthy around here
Globaldata- https://www.globaldata.pt
Pcdiga- https://www.pcdiga.com
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16476062
How long is too long?
https://pt.pcpartpicker.com/products/video-card/#c=427,448,424,497,513,494,508,506,552,553,522,526,501,523,495,496,571,558&sort=price&L=69000000,309000000
Though RX 7600 and RTX 4060 are decent choices if you are 1080p.
Also note that the 6650 XT selected is on par with performance as RX 7600, identical chip count, just older generation card.
current PC:
https://linustechtips.com/topic/1577554-need-help-in-upgrade/#findComment-16476073
