are all fans in the motherboard?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1576877-please-help/#findComment-16468634
12 minutes ago, GreenLeaf said:
i think i broke the header
not likely if all you were doing was changing settings in software.
Does your BIOS have any RGB control settings? I know it's not common but it's worth checking
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1576877-please-help/#findComment-16468637
<-- Moved to Troubleshooting -->
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1576877-please-help/#findComment-16468666
7 minutes ago, GreenLeaf said:
i odnt think so i have a gigabyte b760 ds3h ddr4
Uninstall Gigabyte's RGB Fusion if you have it. It will clash with Signal RGB.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1576877-please-help/#findComment-16468735
1 hour ago, GreenLeaf said:
i dont have it
You might try OpenRGB to see if that  can force the LEDs to change
Primary PC:
PSU tier list
https://linustechtips.com/topic/1576877-please-help/#findComment-16468778
7 hours ago, GreenLeaf said:
daisy chained to one motor header and one RBG header
you could try carefully re-doing the cables for the fans
current PC:
https://linustechtips.com/topic/1576877-please-help/#findComment-16468869
