In fact, I am confused about choosing the components for my computer, and I do not know which ones are the best and if they are compatible or not. I need some help. Thank you very much.
And these are the components I am considering buying. Are there any issues with these parts or not?
MB: GIGABYTE Z790 AORUS ELITE AX
CPU: I7 14700K
RAM: 32GDDR5 7800 RGB
GPU: RTX 4080 SUPER GIGABYTE GAMING OC
M.2: NVME 1TB AORUS ARGB G4 or GIGABYTE AORUS Gen5 12000 SSD 1TB PCIe 5.0 NVMe M.2
PSU: AORUS 1200W ARGB
CASE: AORUS C501
COOLER: AORUS LIQUID 360X WATERFORCE X LCD
My monitor is a Samsung Odyssey G7 27inch 240mhz
is there anything unsuitable in these components? And what are the alternatives for the incorrect items? Thank you again♥ ❤️
https://linustechtips.com/topic/1576055-need-some-help/
Why so much aorus?  I don't know if I've ever seen someone stack that many gigabyte products on one build before.
Will they all work?  Sure, everything you list will work together.
Is it a good value?  I'd guess "almost certainly not"
What exactly are you looking for feedback on?
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461597
Would be pointless to buy because your board doesn't have a PCI-E 5.0 M.2 slot.
11 minutes ago, SirDevil said:
CPU: I7 14700K
Not super familiar with overclocking memory, but that's a very high speed. From what I'm aware of, up to 7200 is fairly safe for Intel 13th/14th gen, but above that you can have problems. Likely to be fine if you're willing to tweak, but otherwise I'd consider something more safe.
If you give us an overall budget and say what your PC is being used for then we can offer alternatives, but it would help if we knew what price you were paying for those parts individually.
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461599
actually, I think if I got most of the parts from the same brand it could be more compatible, so what do you prefer to build something like that 🙂
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461603
brand compatibility doesn't mean anything, it's not a thing.
All parts are standardized as long as you get the right type of CPU and RAM to go with the motherboard.
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461609
  1. 1*SMD PCIe 5.0 x16 Slot with Ultra Durable™ Armor doesn't it mean its supports the PCI 5?
  2. about the RAMs I could check it again and I will take your advice thanks may I go with 7200 or 6xxx
  3. the over budget 3k dollars or more little bite 😄
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461610
good, so what do you think or the good build I can go with bro
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461611
the x16 slot is for the GPU.
The M.2 slot is PCIE 4 for the NVME Drive.
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461612
9 minutes ago, MiszS said:
Are you going to be just gaming, or doing something else CPU intensive? Because if no, the 14700k is a worse option than the 7800X3D. You also don't need a 1200W PSU, a 1000W one would be still more than enough
for now its just gaming maybe some little video editing as learning, yes I knew this PS is over, and why I'm here to ask for experience people like all of u here to got help and my right build thanks
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461613
ok fine so i can go with Samsung Evo 980 or something, but for the main build, I am still not sure which MB with this CPU, and the cooler, etc Do you have any suggestions from your side?
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461615
You can fit in a 4090 for that budget, even including most of the Gigabyte bling in your original spec.
PCPartPicker Part List: https://pcpartpicker.com/list/RzV8GP
CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor  ($369.99 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: Gigabyte Z790 AORUS ELITE X AX ATX LGA1700 Motherboard  ($219.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-7200 CL34 Memory  ($105.99 @ Amazon)
Storage: Gigabyte AORUS Gen4 7300 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($139.99 @ Newegg)
Video Card: Gigabyte AORUS MASTER GeForce RTX 4090 24 GB Video Card  ($1804.00 @ B&H)
Case: Gigabyte AORUS C500 GLASS ATX Mid Tower Case  ($199.99 @ Amazon)
Power Supply: SeaSonic FOCUS GX-1000 ATX 3.0 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Newegg)
Total: $2995.84
Generated by PCPartPicker 2024-07-09 11:15 EDT-0400
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461661
Total: $2995.84
The price of this card is unfortunately very high in my country, around $2000,, that's why I picked RTX 4080 supper, and thanks for your help and your time sure to give me a good feedback bro
https://linustechtips.com/topic/1576055-need-some-help/#findComment-16461678
