Fan question/recommendations
Go to solution Solved by GuiltySpark_,
2 minutes ago, Ronnmann said:
I just found the DeepCool CF 120 Plus 3in1 for 38€. Price is very good i guess, but i have never bought a DeepCool Product by now. Are they good?
Sure, they'll be fine for general case fans. I have a number of DC coolers, all great. Contraband now in my country 🤣
Heyyo,
im in a bit of a pickle here and i don't quite know the ARGB setup, so i need a plan of attack here. 😄
Now i have a Lian Li Lanncool 216 RGB with it's Fan Hub on the back. One of my 3 Top fans broke so now i have a reason to upgrade all 3 of those (Non RGB) to ARGB ones. (120mm)
Right now i control all of my little RGB (Front Case fans and GPU) with the Gigabyte Mainboard software from its ARGB Header.
Now my question is.
Can i just use the integrated hub with it's Rgb control through the Mainboard to control the three new ARGB Fans (When i plug them into my Hub, or should i just buy a ARGB Hub?
That's the controller i have:
https://linustechtips.com/topic/1576053-fan-questionrecommendations/
That appears to have the capability to do what you want, assuming its correctly advertised as an ARGB hub, so 3-pin 5v.
Based on the below from the manual, yeah that'll do exactly what you need. Powered and passthrough ARGB to the motherboard for software control.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
2 minutes ago, Why_Me said:
You should be able to control them with your board after downloading Gigabyte Fusion. If not then look at this link.
https://lian-li.com/product/uni-fan-sl-v2/
He does not have Unifans, as far as i'm aware.
2 option, cheapest good RGB fans,
or just buy with whatever other RGB fans you may have in case if any so they look uniform,
a similar fan for the front case might be tricky to find, therefore the best case fan for the job is none other than ARCTIC fan: (in a 3 pack)
Case Fan: ARCTIC P12 PST A-RGB 0dB 48.8 CFM 120 mm Fans 3-Pack  (€38.95 @ Amazon Deutschland)
Cheap and quiet.
Or, I actually found something similar to the front fans,
this build uses these:
Case Fan: Cooler Master MasterFan MF Halo 47.2 CFM 120 mm Fans 3-Pack  (€47.76 @ Amazon Deutschland)
current PC:
PC configs I used before:
He doesn't have any fans yet.
ye but those are expensive
current PC:
I do have 3 Be quiet pure wings 2 120mm right now. ^^ (one of them broke as i said)
But i want some more rgb because my pc is almost only black with those ^^"
I will replace all three on top with ARGB ones because of that.
Is it worth it to buy the more expensive ones like from Lian Li or should i just stick with good looking Cooler master/any RGB Fans ?
Thats hilarious xd
Okay then, thanks to all you guys helping me with this 🙂
