Validated space? I need HELP
Go to solution Solved by Needfuldoer,
9 minutes ago, jar3av said:
the game isnt installed tho the 73 gigs are just unused and cant be used
Delete the files.
There's probably a hidden file (or folder full of files) eating that space up.
https://support.microsoft.com/en-us/windows/view-hidden-files-and-folders-in-windows-97fbc472-c603-9d90-91d0-1166d1d9f4b5
So I accidantly validated about 70 gigabytes to game I dont want to install on my hard drive how do I remove validated space cause i cant use those 70 gigs of storage now I have 1tb hard drive split to 2 local disks one of them (the one where I validated the space)has a game on its own nothing else I cant delete the files so for example I have 500 gigs if i validate 70 I will have 430 usable nothing is inside the hard drive but still 70 gigs are validated how do I unvalidate
https://linustechtips.com/topic/1575490-validated-space-i-need-help/
Delete the files.
Use TreeSize Free in admin mode and see where the space is used.
You probably have MS store packages installed on that drive, and they'll be in a hidden folder.
F@H
GPD Win 2
6 hours ago, Needfuldoer said:
Delete the files.
Thank u so much man i needed this space thnx
