I'm looking for a new laptop right now and based on my own research I've mainly narrowed it down to two options. I'm looking at the Zenbook 14x OLED and the Proart PX13. I do a pretty even mix of creative applications, gaming, and development (I also use virtualization semi-often). I know the PX13 is still on pre-release, but I didn't know if anyone had any thoughts on which one would be better. They are both currently on sale at best buy, the zenbook for ~$1500 and the PX13 for ~$1700. Anyone have any idea which of these would be a better choice?
https://linustechtips.com/topic/1575279-need-help-choosing-between-2-laptops/
6 minutes ago, Arasnsv said:
I think so. The Best Buy listing says HN7306WU, but I'm pretty sure it's the same. The Px13 is definitely better spec-wise, I just wasn't sure if anyone thought that it was enough of an increase to warrant the price difference.
The WU variant is different than the WI. The WU has a 4050 not a 4070 like the WI. The WU also might come with a 'slower' CPU with less cores. Might also come with less memory.
You can compare specs of each PX13 here:
ProArt PX13 (HN7306) - Tech Specs|Laptops For Creators|ASUS Global
