Budget (including currency):  $1300-1400 CAD
Country: Canada
Games, programs or workloads that it will be used for: Valorant, GTA , Elden Ring, AAA games, Streaming 1080p and editing and rendering.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  just need a monitor pref 160 -240 (1440p) but that doesn't have to be part of the budget! Would be nice if possible but not trying to go way over. $1500 is the MAX MAX. (I know this is a stretch but white theme if possible). Thankyou so so much guys. 🙂
https://linustechtips.com/topic/1574712-pc-build-recommendation/
I've managed to build a PC that might be able to do what you want. I'm unsure about the GPU and CPU combo if it can run AAA titles at such frame rates, but there should be some headroom. It'll cost around $1356.59 CAD.
https://ca.pcpartpicker.com/list/v7TFVW
Don't tell me to upgrade. I would've done so if I could.
Country: Canada
Don't think you can get a 1440p monitor with the budget, it'll cripple your GPU budget and then it won't be good at 1440p
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($247.96 @ shopRBC)
Motherboard: Gigabyte B650M GAMING PLUS WF Micro ATX AM5 Motherboard  ($195.80 @ Vuugo)
Memory: Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory  ($127.99 @ Amazon Canada)
Storage: TEAMGROUP MP44L 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.96 @ Canada Computers)
Video Card: XFX Speedster QICK 319 BLACK Radeon RX 7700 XT 12 GB Video Card  ($554.99 @ Memory Express)
Case: Montech AIR 903 BASE ATX Mid Tower Case  ($94.99 @ Newegg Canada)
Power Supply: Corsair RM750 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($124.99 @ Newegg Canada)
Total: $1436.68
Generated by PCPartPicker 2024-06-25 02:59 EDT-0400
Total: $1436.68
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($248.98 @ Amazon Canada)
Motherboard: ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($173.99 @ PC-Canada)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($139.99 @ Canada Computers)
Storage: *TEAMGROUP MP44L 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.96 @ Canada Computers)
Power Supply: MSI MAG A750BN PCIE5 750 W 80+ Bronze Certified ATX Power Supply  ($89.99 @ Memory Express)
Total: $1392.89
Generated by PCPartPicker 2024-06-25 05:22 EDT-0400
if u want A-Tier PSU there's slightly cheaper in Canada:
Power Supply: Super Flower Leadex III Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($122.97 @ Amazon)
current PC:
PC configs I used before:
or RMe, or
Power Supply: ADATA XPG CORE Reactor 750 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
F that's US, hold on,
really good B-tier units instead:
Power Supply: MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.98 @ Amazon Canada)
Power Supply: Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Canada Computers)
current PC:
A mix of black and white, some white parts are overpriced. Smaller mATX board will look neater in an mATX case, a fit for fit:
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($249.00 @ Amazon Canada)
CPU Cooler: Deepcool GAMMAXX AG400 ARGB 75.89 CFM CPU Cooler  ($20.30 @ Vuugo)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($78.95 @ shopRBC)
Video Card: XFX Speedster SWFT 319 Radeon RX 6800 16 GB Video Card  ($555.29 @ Amazon Canada)
Case: SAMA ARGB-Q5 MicroATX Mini Tower Case  ($74.98 @ Newegg Canada)
Total: $1392.49
Generated by PCPartPicker 2024-06-25 05:53 EDT-0400
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
