Need help Identifying Electrolytic capacitor
Solved by Bitter,
35v 4.7 uf probably. https://www.mouser.com/c/passive-components/capacitors/aluminum-electrolytic-capacitors/aluminum-electrolytic-capacitors-smd/ you'll need to measure the dimensions to get the matched part.
Jimkirk363 ·
Posted in Windows0 -
Ramrod126 ·
Posted in Cases and Mods0 -
smush ·
Posted in CPUs, Motherboards, and Memory5 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
3
1
