I do a lot of work in Computer Aided Design software such as SolidWorks, I was planning on upgrading my system and wondered what you guys recommend to be used for this purpose, such as should I buy more ram (8gb),better video card(Amd radeon 6750), or what?
Does not having a second parenthesis around something bother anyone else as much as it does me? (Like if this statement was missing a second side)
https://linustechtips.com/topic/15729-best-computer-for-cad/
4 core+ CPU hyper threading will help so maybe a 3770K. Maybe go with the 2011 socket if you have the money.
16GB RAM should be more than enough unless you are doing very large/complex models.
For a GPU I recommend getting a Nvidia Quadro GPU, it will work very well with Solidworks and AutoCAD(AMD Firepro GPUs are also supported for GPU acceleration). Just choose one that fits in your budget: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100008333%20600044686&IsNodeId=1&name=NVIDIA
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177139
Ok thanks im looking at the new amd fx 8350 for a new cpu because the motherboard i have will handle up to 8 cores, are you sure that AMD GPU's dont support GPU acceleration?
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177154
To my experience, gaming grade GPUs are bad at CAD, but then again, I've never used SolidWorks, so I don't know if it helps there. If you want a Pro grade GPU, you're quickly talking big cash for high end. GPU is important, but depending on your budget, I would probably go with some memory and CPU cores.
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177158
Yeah the Fx 8350 will work great, and after looking around online, looks like they have enable GPU acceleration with AMD GPUs, but only the Firepro workstation cards.
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177175
I know there used to be some hacks one could to with nVidia cards to lure the system into thinking it was a pro card, now, that particular one got shut down but, there might be others. There might be some hack for AMDs too...
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177183
Didn't you have to solder some connections on the PCB to do that? I would NOT feel comfortable doing that.
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177232
To be honest, I'm not entirely certain. I would't be surprised it soldering was a part of the scheme, the guy who told me about it was the kind of a guy who would hard modify his stuff. But I would snoop around for some software hacks.
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177262
Budget is about 400 bucks so not enough to completely rebuild computer, but enough to upgrade about 2 parts. I'm using a TV and another monitor right now the monitor running at 1440 by 900 and the tv running at 1080p. For peripherials im currently using the mouse and keyboard that came with the computer, however they work very well and the keyboard is mechanical. I also use the computer for a little gaming on the side, but nothing to serious it is mainly my workstation. I am using CAD as a student.
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177302
I would drop some cash on one of these http://www.3dconnexion.com/products/spacenavigator.html I have one, and I recommend anyone who's doing a fair bid of CAD work to get one.
What will you be CADing? Huge and complex models, assemblies and such? Or will you be doing FEM and optimization on fewer parts at a time? Or will you maybe be doing surface modelling?
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177328
Individual parts for right now but in the future hope to do more complex assemblies. The most complex one I've got so far is a truck without the underside components.
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177479
Then you should be fine without a badass supported graphics card ;) If you get a good CPU and some ram, you could always add on a graphics card later if you get the money and/or if need it
https://linustechtips.com/topic/15729-best-computer-for-cad/#findComment-177497
