1 hour ago, Pirateben said:
No room for an ssd ..I could get an m.2 adapter and use that for the os... the adapter allows for 2 m.2 card you think I should put them in a raid then add the hdd in there own raidz2 and what raid would the m.2 be raid 1?
What adapter? Make sure it has bifurcation support.
What raid card does the server have? If it has hardware raid, use the hardware raid card, and you can also boot from the main array if yo want.
What os are you using? I'd try to get ssds as hdds are gonna be slow for vms.
https://linustechtips.com/topic/1572688-raid-configure-help/#findComment-16430599
5 hours ago, Pirateben said:
I got a new server and it has 8 1.2tb hdd it is a poweredge 730xd from Dell what would be the best set up for having the os being installed and the rest for vms and what not
Give Unraid a shot as it runs from a USB drive so doesn't take up an existing hard drive. Its not free but worth it imho.
You'll definitely need an SSD in there as a cache drive. You're VMs will be super slow running from spinning metal.
Can you sacrifice an existing hard drive to make space for an SSD and run it with single parity allowing for one drive to fail?
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1572688-raid-configure-help/#findComment-16430649
The adapter  is this one https://cloudninjas.com/products/supermicro-nvme-m-2-pcie-adapter-card from this video
I do have a hardware  controller  card it is this one RAID Hardware: Dell PERC H730 1GB Cache Mini Mono RAID Controller
I want proxmox as the server os then a vm for local ai one for docker one as a Nas and maybe one for gaming...I got hdd and not ssds because the trays are 10$ and a tray and 1.5 tbs hdd was 20 but an ssd was 100+ each so if I need more I'll upgrade
https://linustechtips.com/topic/1572688-raid-configure-help/#findComment-16430650
I want to add a vm as a Nas like that they are HDD 1.2TB SAS 10K 2.5 12Gb/s with Tray caddy look to my post above why I picked them
https://linustechtips.com/topic/1572688-raid-configure-help/#findComment-16430652
Was just thinking about performance when writing to the array.
My Unraid server has all docker containers and VMs running within the Cache and any file moves or writes set to cache > array with a 'mover' scheduled to run every day at about 3am.
Without that, my whole array would slow down as it will be stuck writing parity although you may not have that issue with 10k SAS drives.
https://linustechtips.com/topic/1572688-raid-configure-help/#findComment-16430750
I'd be tempted to skip the SSD boot drives and boot from the main array. Then setup a hardware raid 10/6 and put your VMs on it. Should be slow but doable performance here.
https://linustechtips.com/topic/1572688-raid-configure-help/#findComment-16431204
