Guys, needing some extra help here.
Took the day off to clean up my pc and install a new CPU cooler on my Ryzen 5 3600x, I've been using the box one since I bought it and it wasn't performing as it should, so I got the cheapest one from Amazon (Cooler Master HyperT20) and tried installed it today.
Had some trouble cause this one uses that hook system and I had to apply a lot of pressure, getting to the point of bending the heatsink, when I finished assembling the computer, it wouldn't turn on while troubleshooting what might have happened I thought about the CPU and tried to remove it and turn it on without it, and it works, but when I put the CPU back on, even without the cooler, and press the power button nothing happens.
I'm welcome to suggestions of what to do or try next, even though I'm almost sure it's a goner, also attaching pictures of how the heatsink turned out.
Sorry for any typos or inconsistencies
https://linustechtips.com/topic/1572570-pc-wont-start-with-cpu/
Your CPU is in the socket sideways....
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1572570-pc-wont-start-with-cpu/#findComment-16429562
1 minute ago, Danielsps said:
Nah bro, i aint THAT dumb hahaha, if you're looking for the golden arrow it sits under it, and on the other side.
Still, it wouldn't even fit if it was sideways...
That CPU is not all the way in the socket. It's sitting on the edges of the socket. It almost looks like it was put in the socket with the retaining mechanism latched down.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1572570-pc-wont-start-with-cpu/#findComment-16429573
Just to update it, to be sure I tried putting the CPU on top of the socket, without locking it, and then turning it on, it's just when I try locking it that the PC turns off, not sure if it's really the CPU ou could be the motherboard socket, sending video below.
https://linustechtips.com/topic/1572570-pc-wont-start-with-cpu/#findComment-16429577
I mean, that picture is from some hours ago, right after setting the cooler, but im positive that the cpu was right, either way, thats does not seem to be the problem now, i'm sending a link (too big to upload here) to a video i took right now, showing that the cpu is rightly seated and that it only turns on when the latch is up.
https://photos.app.goo.gl/sxXFnRFQHNDGUXxD9
Anyway, thanks for the help bro, just wish i had another cpu to test if it really is it or the mobo.
https://linustechtips.com/topic/1572570-pc-wont-start-with-cpu/#findComment-16429580
Pull the CPU out and check for bent pins. If it doesn't have bent pins you probably broke the socket applying to much pressure when mounting the cooler. The cooler should not have taken enough pressure to bend it like that to install it.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1572570-pc-wont-start-with-cpu/#findComment-16429583
It doesn't, im pretty sure its the mobo, but i wish i had a way to know for sure
https://linustechtips.com/topic/1572570-pc-wont-start-with-cpu/#findComment-16429594
