So i just installed everything into my case except the gpu and the ram since they havent arrived yet. I hooked up the cpu fan to the motherboard and case fans to my psu. I turned on the power to see if the fans are working and the cpu fan isnt moving at all. The case fans are working but the cpu fan is not. Is this suppose to happen?
https://linustechtips.com/topic/157098-heatsink-fan/
What motherboard have you got ?
(better yet please list your PC's specs)
Some motherboard (like Gigiebyte) manufactures like to so a cool and quite tech my default. so the cpu fan will not spin up until it hits a pre set temp
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/157098-heatsink-fan/#findComment-2093728
Never a good idea to start up a pc without memory and graphics. Anyways, have you checked the PSU connections to the motherboard (do you see any ligths flickering?)? Have you connected the CPU fan connector the right way? Is the CPU fan broke (have you tried another one?)?
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
https://linustechtips.com/topic/157098-heatsink-fan/#findComment-2093731
You might need RAM to even see if it works. Mine was like that.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/157098-heatsink-fan/#findComment-2093733
Some motherboard (like Gigiebyte) manufactures like to so a coll and quite tech my default. so the cpu fan will not spin up until it hits a pre set temp
http://pcpartpicker.com/user/darkn3ss/saved/4CET
https://linustechtips.com/topic/157098-heatsink-fan/#findComment-2093745
WIll it cause any serious damage turning it on without the ram and cpu? This is my first build so im worried im gona screw up but other then the cpu fan, everything else seems to be working.
nothing bad will happen if you do that
person below me is a scrub
https://linustechtips.com/topic/157098-heatsink-fan/#findComment-2093795
