Reviving an old PC with a 1070Ti >:) (and other plans)
7 minutes ago, Maisa said:Looking to buy a 1070Ti + 600W PSU I know it is kinda overkill but I want to have the pc working now and upgrade it down the line.
In the market right now 1070Ti s are going for around 150$ and the PSU that I think would be good for the build is Thermaltake Smart RGB 600W 80 Plus - 70$.
The 1070 to seems a bit pricey for $150, but if that's your local market and the price is fair compared to something like a used RTX 2060 or RX 6600, then it's a good option. In the United states, I would expect to pay closer to $100 for a used 1070 ti.
The thermaltake smart, on the other hand, I would recommend against. Look at some Be Quiet power supplies around the 550 watt range.
7 minutes ago, Maisa said:With the other budget i'm planning to buy RAM since this PC only has 6GBs of DDR3 and here I a have another dilemma : Instead of buying DDR3 for the setup, can I instead buy DDR4 RAM and put it in this motherboard? So I don't spend money again on RAM when I upgrade the motherboard in the future. I've heard it's only downside would be that it would run at lower speed.
Your 3rd Gen i5 has a memory controller that won't know what to do with DDR4, so even if a physical adapter existed to put DDR4 into a DDR3 slot (I don't think such a thing has been created), the CPU wouldn't recognize it.
