Hi, i have had a GTX 1070 for 4 years now, but when i got it it seemed like my pc couldn't run games that it should be able to, when i wanted to run a newer game like RDR2 or Death Stranding the game started but crashed in a few minutes, then after a while  couldn't even start the game, it instantly crashed, first i was thinking that it was a CPU problem (i have a i3 10th gen) so for years i just moved on, and didn't play games that i wanted to. A few months ago i got angry, (because a 1070 is an expensive GPU) and i started to troubleshoot yet again, i downloaded a game that i couldn't run before, and watched the task manager, and i realised that before crashing the GPU percentage went up to 100% and than crashed. Somehow i had the idea to underclock my GPU by 100, and IT WORKED, i can run ANY game now, but i would like to know why that is, if anyone knows what could be the problem tell me pls, and if you have a similar problem download MSI afterburner and try underclocking your GPU.
UPDATE:
I bought and installed a new psu (Yanx 700W 80 plus gold), and the problem is still present soooo, wasted some money
https://linustechtips.com/topic/1567804-gpu-problems/
maybe your psu is struggling with voltage, since 'underclocking' with msi afterburner is essentially the same as 'undervolting'. I did it too and I gained about 100 fps in rocket league with a 3060 12gb (250 to 350) while using the same power
How old is your psu and what model is it?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1567804-gpu-problems/#findComment-16389056
1070 is pretty old, I suspect thermal issues, did you check temps and clean/repaste it ?
100% usage is expected in gaming (unless CPU bound)
https://linustechtips.com/topic/1567804-gpu-problems/#findComment-16389065
