Help
Go to solution Solved by Hinjima,
5 minutes ago, Champs said:
Today I was playing in my bios and when I restarted the pc it didn't showed anything 馃ゲ. Pls help me I don't know what I've done 馃槶
Remove the CMOS battery for 5 minutes, put it back in and try again.聽 This will reset any changes done in the BIOS to default settings 馃檪
maybe be more specific. what did you do in bios? try holding the f12 button while turning on the PC. if that works, then reset the bios to factory defaults
Make sure to mark solutions, as it helps us find people who need help faster.聽Thanks!
I am human and am therefore prone to error, so I apologize if I make mistakes and I hope you understand.
Have a Nice Day!
https://linustechtips.com/topic/1567724-help/#findComment-16388620
https://linustechtips.com/topic/1567724-help/#findComment-16388624
