1440P Monitor Undecided
3llyas
So I have been looking for a 27" 1440P (QHD) Monitor and these two are the ones I found which are right around my budget, but I can't choose between one of them:
Both of the monitors are IPS.
What do you think and any suggestions?
EDIT : Found an in-depth review for the Viewsonic, though I am too dumb and need a layman's term and a TLDR. Couldn't find an in-depth one on the Acer though
Edited by 3llyas
On paper the Acer is better having that LED panel. otherwise the specs look the exact same.
CPU: Intel Core i9-10900K 3.7 GHz 10-Core Processor
CPU Cooler: ASUS ROG RYUO III 360 ARGB White Edition All-in-one AIO Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z490-E GAMING ATX LGA1200 Motherboard
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3200 Memory Boosted to 4400MHz
Storage: 6 various HDDs and SSDs
Video Card: ASUS ROG Strix 3090
Case: Lian Li O11 Dynamic XL
Power Supply: Asus ROG Thor 1000w
Operating System: Microsoft Windows 11 Pro
Monitor: Samsung Odyssey G9 OLED 49"
Keyboard: Logitech G915
Mouse: Logitech G502 LIGHTSPEED
Headphones: Sennheiser RS 175
Mic: Blue Yeti
I'm pretty sure the LED is just a naming marketing jargon no(?) as both are IPS LCD screen?
No, IPS an VN panels are LCD and require a backlight behind the panel itself. An LED panel, each pixel emits it's own light. This is why in the case of OLED, they boast about the black levels because the pixels themselves actually turn off. You will get better picture quality over the IPS with LED but you lose the response time. So if you're playing competitive shooters you may want the ViewSonic. If you prefer an overall better experience in more casual and story driven games then the Acer would be the way to go.
Mic: Blue Yeti
Yeaa I know that, what I meant is that the Acer monitor is an IPS panel and not an LED(OLED) panel.
No, it better be an LED monitor. If it isn't then that's some really bad false advertising.
Mic: Blue Yeti
The product page makes it pretty clear it's an LED-backlit LCD (IPS-type).
LED-backlit monitors have been commonly labeled as "LED monitors" for over a decade.
well that's dumb. good to know.
Mic: Blue Yeti
I would choose the ViewSonic monitor because it's better-designed for serious, professional gaming and it has DisplayPort 1.4.
I would choose the Acer monitor if... uh, I really care about the built-in USB ports.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
