hey guys,
So I'm thinking about making the jump from amd to intel and i'm pretty much set on getting a i7 4770k but of course I need to buy a new motherboard. I have around £190-220 to spend and would really like some recommendations.
What have you used and liked?
This is the one that's stood out so far for me: http://www.overclockers.co.uk/showproduct.php?prodid=MB-607-AS&groupid=701&catid=5&subcat=2811
Thanks guys!
https://linustechtips.com/topic/156751-motherboard-advice/
If you don't need any special features, pretty much any 1150 zX7 motherboard will do.
https://linustechtips.com/topic/156751-motherboard-advice/#findComment-2089407
I second this.
You gotta do you girl. I always say you gotta do you. And if he's doing him, then who's doing you? Because right now, it seems like no one's doing you.
- Stefani Stilton (she / her) 🏳️‍🌈🏳️‍⚧️
https://linustechtips.com/topic/156751-motherboard-advice/#findComment-2089414
ah okay!
Any specific suggestions?
If it's purely for gaming with an overclock I'd recommend the Z97 MPower non ac or the ac model. Gigabyte Z97X-soc?
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/156751-motherboard-advice/#findComment-2089455
Yeah it's for gaming with oc and running 3-4 monitors at a time (obviously through the gpu haha)
Thanks for the speedy responses guys!
https://linustechtips.com/topic/156751-motherboard-advice/#findComment-2089464
If you don't plan on doing balls to the wall oc (anything 4.5ghz above),you get can just get a normal decent motherboard. Even a 70pound gigabyte motherboard can achieve that kind of oc just fine. You don't need to spend that much on a motherboard UNLESS you REALLY need a certain feature on it or you just prefer the look of it (which is not a smart buy imo). Motherboards,they either work or they don't. No increase in gaming performance whatsoever.
Spend that extra money and upgrade your other pc components or treat yourself to a nice dinner or movies.
https://linustechtips.com/topic/156751-motherboard-advice/#findComment-2089478
I'd get a 1440p vs triple screen 1080p
https://linustechtips.com/topic/156751-motherboard-advice/#findComment-2089488
