Graphics issue??? Solved? PCIE Bus Lane Issue - Riser Cable Old
15 hours ago, XxK3V1NxX said:If you have an SSD or HDD that you do not use, try installing Windows, since it may be a problem with the operating system or some other controller of some component.
If that doesn't work and you have the possibility of touching the VRM heatsink or them, make sure they don't have high temperatures, since it could be a defect in the motherboard.
Likewise, i didn´t not agree with the excessive use of the GPU without doing anything
Hello @XxK3V1NxX,
I've Checked the Mobo all over with a thermal imaging camera, Nothing seems out of place or alarming.
I don't have HDD or SSD lying around but as a trouble shooting step I've already re-installed windows on both my m.2 Drives.
As an update I think my GPU Riser Cable may be causing issues. It came with my case which is an older case Thermaltake P3. I noticed on the GPUZ my GPU is running x4 3.0. With this information I remembered that my GPU and the GPU Control software sometimes cannot seem to talk to each other.
I was using the Riser due to the GPU interfering with the Radiator. This being an unconventional case I can't mount the radiator anywhere else so the Picture attached is my current situaton.
I know its not ideal but so far I'm running 16x 4.0, the Gigabyte Software is actually working with the GPU for the 1st time.
I should be building a new PC in a couple of months and my brother is going to take this one (with a new case!). So I'm planning on Tie-Wrapping the radiator pretty much where it is now for the time being.
Not pretty, and I don't want to curse it. But so far it's running a lot better.
