Upgrade from current build, no concrete timeline.
Solved by Dedayog,
46 minutes ago, adinz said:Good to know, I'm just clarifying that stability is not something I'm considering. As for budget I think 600 dollars will be enough, especially if I take a look into the used market. Unless you have a suggestion, I'm not experienced on what is and what isn't a good budget for this kinda stuff.
Best deal hands down is the 7800x3d bundle from Microcenter, but you say it's not open yet?
