Hey so this is my first time posting on the forum, and i been watching Linus for ages. but anyways i could really use some help with a new personal project i'm working on about what hardware to chose.
im building a new rig and im looking at gaming heavily But also a lot of video editing and rendering..
i have got my GPU sorted (GTX 680 classified 4GB 1.1 GHz core clock 6GHz memory clock - this will be overclocked considerably)
but unsure whether to get [i7 3770K @ 3.5] or [FX-8350 8 core @4.0GHz] so from there i can decide on a motherboard and finally chose between a windowed 500R with water-cooling on show, or 500R with closed case with H100I's and less show off motherboard(probably cheaper)
so what im asking is, do i go for the Intel or AMD CPU I've talked about? remembering this is for gaming and video editing
and the second question is do i cheap out on motherboard and go non-windowed case, or or go for a nicer motherboard and go out on water-cooling? also which would cool better, H100I's on cpu and gpu, or a full water circuit
im just rambling on now, with the cost of the nice motherboard and full water circuit i could probably get another GTX 680 or pocket the extra cash
https://linustechtips.com/topic/156708-help-on-new-build/
budget is around £1.3K for this one,
using last gen gpu mainly because i already have a gtx680 and im very happy with performance, unless i can find one for £250-300 that works better with same memory? what new gen components would you suggest?
use is gaming mainly but also video editing and rendering
thankyou
https://linustechtips.com/topic/156708-help-on-new-build/#findComment-2088906
thankyou
You could get a R9 290 to replace your GTX 680.
@TheZinex will you be salvaging any parts from your current pc?
Hey! Welcome to the Linus tech tips forum.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/156708-help-on-new-build/#findComment-2088923
Defiantly go with the 3770k (Upgrading to a 4770k would be even better :P
widget.png?style=banner2
PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7
NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
https://linustechtips.com/topic/156708-help-on-new-build/#findComment-2088936
thankyou for suggestion
the clock speed of a GTX 680 is 1111 MHz on a R9 290 its only 1000 MHz?   is the R9 290 worth £90 more?
just looked into it more:  4GB EVGA GTX 680 Classified, 28nm, PCIe 3.0, 6008MHz GDDR5, GPU 1111MHz, Boost 1176MHz, Cores 1536 = £250 4GB Asus Radeon R9 290 DirectCU II OC, 28nm, 5040MHz GDDR5, GPU 1000MHz, 2560 Streams = £320
:P
https://linustechtips.com/topic/156708-help-on-new-build/#findComment-2088974
CPU:  Intel Core i7-4770K 3.5GHz Quad-Core Processor  (£233.99 @ Aria PC)
CPU Cooler:  Noctua NH-D15 82.5 CFM CPU Cooler  (£75.02 @ Scan.co.uk)
Motherboard:  Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard  (£130.76 @ Scan.co.uk)
Storage:  Crucial M550 1TB 2.5" Solid State Disk  (£339.26 @ Scan.co.uk)
Video Card:  Asus Radeon R9 280X 3GB DirectCU II Video Card  (£229.99 @ Novatech)
Case:  Corsair 300R ATX Mid Tower Case  (£59.87 @ Aria PC)
Power Supply:  XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply  (£35.34 @ Scan.co.uk)
Total: £1249.46
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-24 21:28 BST+0100)
Fixed memory issue.
Le Bastardo+
i7 4770k + OCUK Fathom HW labs Black Ice 240 rad + Mayhem's Gigachew orange + 16GB Avexir Core Orange 2133 + Gigachew GA-Z87X-OC + 2x Gigachew WF 780Ti SLi + SoundBlaster Z + 1TB Crucial M550 + 2TB Seagate Barracude 7200rpm + LG BDR/DVDR + Superflower Leadex 1KW Platinum + NZXT Switch 810 Gun Metal + Dell U2713H + Logitech G602 + Ducky DK-9008 Shine 3 MX Brown
Red Alert
FX 8320 AMD = Noctua NHU12P = 8GB Avexir Blitz 2000 = ASUS M5A99X EVO R2.0 = Sapphire Radeon R9 290 TRI-X = 1TB Hitachi Deskstar & 500GB Hitachi Deskstar = Samsung DVDR/CDR = SuperFlower Golden Green HX 550W 80 Plus Gold = Xigmatek Utguard = AOC 22" LED 1920x1080 = Logitech G110 = SteelSeries Sensei RAW
https://linustechtips.com/topic/156708-help-on-new-build/#findComment-2089003
what about this build guys? http://gyazo.com/0200a11ad48ee44a3d9828afb9be867e or could be I7 3770K version once ive looked deeper into graphs and stuff about how good they are in my applications
or this build without the H100i's and watercooling circuit and windowed case?
or even this with two GTX 680's? sorry readon, like the cuda cores and i like this GPu as ive used and overlcocked many before
thankyou for previous help tho guys
https://linustechtips.com/topic/156708-help-on-new-build/#findComment-2089254
