Budget (including currency): About $550 USD
Country: USA
Games, programs, or workloads that it will be used for: Mainly coding, compiling, website hosting, and storage.
I have chosen most of the parts already, but I wanted help with a few things. First off is the CPU. I was thinking of an intel core i9-9400, but I wanted to ask you guys because you have more experience with this sort of thing. Finally, the case. I am looking for one with an ATX profile, NO RGB LIGHTS or other fancy gamer stuff, and lots of HDD mounts (I have lots of 1 TB or more HDDs lying around.) Any recommendations would be much appreciated.
https://linustechtips.com/topic/1566595-mini-server-build-help/
7 hours ago, Electronics Wizardy said:
What parts do you already own?
Heavy emphasis on this. For just individual web hosting and storage, you dont need a lot of computing power. Jeff Geerling even only uses cluster of Raspberry Pi to host almost everything online that he has.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1566595-mini-server-build-help/#findComment-16380630
I will also be compiling code and programing.
https://linustechtips.com/topic/1566595-mini-server-build-help/#findComment-16381138
On 4/13/2024 at 10:23 AM, Electronics Wizardy said:
What parts have you chosen? What parts do you already own?
9400 is a odd choice if you don't have other parts already or are getting it really cheap.
I do not have any parts yet. What CPU would you recommend then?
https://linustechtips.com/topic/1566595-mini-server-build-help/#findComment-16381140
13600k for igpu, 32gb ram, boot of the ssd and use your hard drives for storage.
the 13600k will handle anything twice as well as a 9400 and has efficiency cores
PCPartPicker Part List: https://pcpartpicker.com/list/dv3q28
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($185.75 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: ASRock Z690 Pro RS ATX LGA1700 Motherboard  ($119.99 @ Amazon)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($59.99 @ Newegg)
Storage: Crucial P3 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($51.25 @ Amazon)
Case: Phanteks XT PRO ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: PowerSpec PS 650BF 650 W 80+ Bronze Certified ATX Power Supply  ($56.99 @ Amazon)
Total: $557.86
Generated by PCPartPicker 2024-04-14 14:58 EDT-0400
https://linustechtips.com/topic/1566595-mini-server-build-help/#findComment-16381146
or this to stay under budget
PCPartPicker Part List: https://pcpartpicker.com/list/NGPMYN
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor  ($162.99 @ Amazon)
Total: $535.10
Generated by PCPartPicker 2024-04-14 15:01 EDT-0400
https://linustechtips.com/topic/1566595-mini-server-build-help/#findComment-16381149
Total: $535.10
Thank you so much
https://linustechtips.com/topic/1566595-mini-server-build-help/#findComment-16382400
