RX 6800 too low 2D/IDLE clock causing stuttering.
On 4/13/2024 at 10:28 AM, 191x7 said:Might be a long shot but...
Have you installed the drivers for your monitors?
Are your GPU drivers up to date?
Checked the other drivers with something like Iobit Driver Booster?
I mentioned the RAM frequency because of the RAM clocks the Zen+ architecture supports.
I was going to recommend Latencymon but you already beat me to it.
Does the same happen when one of the displays is connected to the motherboard (using the GPU integrated in the CPU)? Do you have the APU drivers installed too?
I found what was causing problem - overclocking GPU via Adrenaline was causing this instability, turns out my platform doesn't like it for some reason. I thought that i tested with this setting off, but found out that it was always on. Now i got lagging only when using VM - but i see that it is about CPU utilisation, so i want to upgrade to Ryzen 9 5900X.
I made a new topic about upgrading, maybe you can also look here and tell me what you think.
