First PC build
Go to solution Solved by podkall,
8 minutes ago, Morgann said:
it's just a bit down from $1100, so this should be the perfect one: https://pcpartpicker.com/list/Xsq4QP
yeah it's decent,
if Pure rock 2 is cheaper than AG400 go for it, it's decent, you can also just use stock cooler, but it's fine to have slightly better tower cooler for the boosts,
the motherboard is decent, it has VRM heatsink, it's fine,
the ram is also decent, CL30 is more desirable, even if you drop few Mhz, CL latency means the time it takes RAM to answer a request to read data,
though if you can't find better ram that's fine, this is good,
oh you did find 7600 XT, that's really good as the card despite it being low-midrange, it's got 16GB of VRAM, which is very good for ultra details, and higher resolutions so 1440p and 4K, can stretch to future title games,
case is good as long as he parts fit, mainly GPU, the tower cooler isn't that high and the case is fat on first glance, so only worry is GPU length,
and airflow, but this probably has at least decent airflow,
not bad PSU, I like these protections:(@Somerandomtechyboi would probably agree)
now, you don't need the fans, but you can get additional case fans,
what I'd recommend when buying case fans, this is very unknown but it's very useful,
is this:
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fans 5-Pack  ($23.99 @ Amazon)
a fan pack, also Arctic P12 is very good in US price/performance/amount
now the MB you have has Fan headers for case fans, so you can regulate the speed, which is good so the fans aren't loud, because if you hook up fans just to PSU, they will go 100% speed,
also, let me know what other SSDs are available for you, we could find something better maybe, maybe not
Budget (including currency): 400,000 HUF (around 1100 USD)
Country: Hungary
Games, programs or workloads that it will be used for: Halo Infinite (technically, just pure gaming)
I'm upgrading from an ROG laptop (i5-9300H, GTX 1650 Mobile and 8GB RAM). Mostly 1080p and 144-165hz. I don't have any parts, but I have every peripherals needed.
PPP list: https://pcpartpicker.com/list/L9bjkJ
https://linustechtips.com/topic/1565743-first-pc-build/
How much would something like this cost ya?:
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($199.00 @ B&H)
CPU Cooler: Deepcool AG400 75.89 CFM CPU Cooler  ($21.99 @ Amazon)
Motherboard: *MSI PRO B650M-P Micro ATX AM5 Motherboard  ($119.00 @ MSI)
Memory: *TEAMGROUP Elite 16 GB (2 x 8 GB) DDR5-5200 CL42 Memory  ($48.99 @ Amazon)
Storage: *Leven JPS600 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($99.99 @ Amazon)
Video Card: *XFX Speedster SWFT 319 Radeon RX 6800 16 GB Video Card  ($379.99 @ Amazon)
Case: Phanteks XT PRO ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: *Apevia Prestige 600 W 80+ Gold Certified ATX Power Supply  ($51.99 @ Amazon)
Total: $970.94
Generated by PCPartPicker 2024-04-06 14:58 EDT-0400
current PC:
PC configs I used before:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16373984
Total: $970.94
Sadly, this cost me around 1200 USD. I saw you were recommending me AMD, so I made an AMD list that might work. This build would cost me around 990 USD. What do you think about this list?
CPU: AMD Ryzen 5 7500F ($227.42)
CPU Cooler: be quiet! Pure Rock Slim 2 ($29.10)
Motherboard: ASUS PRIME B650M-A WIFI II ($152.72)
Memory: Kingston FURY Beast 16 GB (2 x 8 GB) DDR5-5200 CL36 ($82.15)
Storage: MSI SPATIUM M450 1 TB ($73.01)
GPU: Asus DUAL OC Radeon RX 7600 8 GB ($299.91)
Case: Cooler Master CMP 320L ($47.46)
PSU: Gigabyte P550B 550 W 80+ Bronze ($51.91)
Case Fans: 2x be quiet! Pure Wings 2 140 mm Fan (2x $12.75 = $25.49)
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374064
Change that ram out, it’s super expensive. Use your fan money and put it into the ram. If you can find cheaper storage at pcie3x or 4c that has the dram then it’ll be faster, but generally if you can find something cheaper it’ll perform sinilarly.
The 7600 leaves a lot to be desired. If you can find any of these cards for cheaper, go with them. Try to buy used:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374070
honestly, doesn't look quite shabby, the only thing I'd change is maybe better PSU and RAM
instead of case fans maybe, or better/different case, some include at least one fan in them
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374093
Found this RAM for $88.29. The case and the 2 fans together are cheaper than a case with 1 or 2 fans included.
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374107
I've got the cheapest option of everything, so I can't get a cheaper SSD. Found this one for $88.29. I would highly avoid used in my area beacuse there isn't a very big choice in what you wanna buy and most of the time. Found this RX 7600 XT for $403.77, which luckly fits in my budget!
Could compare which one is better, with this list?
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374108
that's way better, you could also look for CL30 ram if it's not too much, or CL30 and like 5400Mhz, sweetspot is 6000Mhz and 30CL, but you don't gotta pay fortune if it's too much for you
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374114
No, It perfectly fits into my budget still.
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374118
by the way, you can check on your list, and swap locations, there's Germany and other EU countries that might be close to your budget in € converted at least
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374122
OMG TY I NEVER EVEN SAW THIS, THIS WILL HELP SO MUCH!!
oh there's Hungary, lmao
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374130
Just now, Morgann said:
Just looked, and It's only one website. yikes
Alza is in everyone's wall in EU
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374132
well, you can consider these parts, idk how GPU is expensive, you could swap it to the 4060 if it's the most expensive GPU possible,
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (84390.00Ft @ Alza)
CPU Cooler: Deepcool AG400 75.89 CFM CPU Cooler  (9590.00Ft @ Alza)
Motherboard: MSI PRO B650-S WIFI ATX AM5 Motherboard  (67190.00Ft @ Alza)
Memory: *Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (53490.00Ft @ Alza)
Storage: Western Digital Blue SN580 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (26490.00Ft @ Alza)
Video Card: Asus DUAL OC Radeon RX 7600 XT 16 GB Video Card
Case: Deepcool CC560 ATX Mid Tower Case  (21190.00Ft @ Alza)
Power Supply: *EVGA 600 BR 600 W 80+ Bronze Certified ATX Power Supply  (21190.00Ft @ Alza)
Total: 283530.00Ft
Generated by PCPartPicker 2024-04-07 00:01 CEST+0200
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374135
Total: 283530.00Ft
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374141
yeah it's decent,
is this:
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374154
Count the fans though, if you only want to buy 2, a 3 pack will probably be more expensive, even though the price for each fan is cheaper.
Honestly the MSI SSD isn't that terrible, if you don't have room for slightly better.
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374162
warrantyless but if its cheap enough (<50$) and used doesnt exist then its an ok option albiet effective 522w due to 12v = 43.5a so prefer something with 12v = psu advertised rating like the deepcool pk-d psus since those will be better quality, again depends on price wrther or not its worth it cause a few extra $ is fine but not >10$
Total: 283530.00Ft
also this is pretty much best bang for buck atleast on pcpp and yes i checked most of the parts though instead of the ag400 you can get the freezer 36 for a tad more which should perform better
yes theres an a620 that is half the price of that b650 but that kinda defeats the purpose of am5
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374201
I mean yeah but we're on 7600 range, a stock cooler would be just as fine, but slightly better than stock is always welcome on AM5
current PC:
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374204
eh the wraith stealth is trash, bet even a ziptied on 775 copper core would destroy it in cooling performance, let alone an old amd copper heatpipe cooler or the freezer 36
besides youd probably wanna tune the 7600 anyways and run it abit faster with a higher tdp, but hey its better to be super efficient at 88w stock instead of whatever nonsense the x cpus are running out of the box and drawing tons of power + pegged at 95c
https://linustechtips.com/topic/1565743-first-pc-build/#findComment-16374219
