Laptop Slowdown with Unkown Cause
M.SR
For the past month, my laptop has run incredibly slow to the point I can't even get my job done. I have tried everything I could to solve this myself but unable to fix this issue. It like running on a 500-800 ping even with few basic applications running like Microsoft Edge & Windows Explorer. This is basically a cry for help. So, if there's anyone can help me solve this issue, I would be extremely grateful.
Here's some information regarding my PC:
Model : Lenovo Legion 5 2020
Processor : AMD Ryzen 7 4800H (2.90 GHz)
RAM : 16 GB DDR4
Graphic Card : Nvidia GTX 1650
Windows Edition : Windows 11 Home
Windows Version : 23H2 (Updated Regularly)
The slowdown usually occurs when:
1. I'm copy and pasting a large sum of files.
2. When I left my laptop running overnight with a game open. But after coming back the next morning, the laptop runs incredibly slow.
3. After booting up, the laptop sometimes runs slow. But after a while it returns to normal.
4. The only solution to revert back to normal is to shut down the laptop, wait for a while and turn it back on. But sometimes even this doesn't work, and I have to shut down my laptop multiple times to get it running.
5. There's a time where I run 2 games at a time (Dota 2 & Genshin Impact) and both games can be run smoothly. But when doing minimal task like renaming multiple files, downloading files, the PC becomes slow.
The thing is, I checked the CPU, RAM & GPU usage, and they were all fine. No excessive usage from a single app that could throttle down my laptop. And I only have a few startups app enabled to begin with (Skype, Logitech G-Hub, RealTekAudioService64 & SecurityHealthSysTray). All other startup apps are disabled.
I also have a few 3rd-party programs installed which I doubt that any of these programs gone rouge (I might be wrong though).
- Nvidia GeForce Experience & other Nvidia components.
- GomPlayer
- qBitTorrent
- Discord
- Steam & Dota 2
- Genshin Impact
- Internet Download Manager
- Microsoft PowerToys
- FolderMaker Free
- TreeSize
- WinRAR
Here's some of the fixes I tried previously:
SOFTWARE-RELATED FIX
1. Scanning the whole drive for viruses using Microsoft Defender. All clear.
2. Running checkdisk on all of the drives for corrupted files. None were found.
3. Running disk cleanup on all of the drives.
4. Updating Windows to the current version.
5. Updating BIOS and all the drivers.
6. Turn off the indexing option for Search.
7. Uninstall unnecessary programs.
8. Resetting the PC twice (Remove everything, download Windows from Cloud). Issue still persists.
HARDWARE-RELATED FIX
1. Cleaning all the cooling fans.
2. Re-slotting the RAM, HDD and battery.
3. Re-applying the thermal paste on CPU & GPU (In case the slowdown is due to thermal issue).
But none of these works. My laptop is still experiencing intermittent slowdown from time to time. The worst is when even the mouse movement is painfully slow.
I have done all I have known to fix this. Now it's time to ask for help.
I'm not entirely sure if this is a software or hardware issue.
Hi buddy,
You should try and do a fresh install of Windows.
Resetting is a good shout but I always find a proper fresh install gets a PC back to factory fresh unless there's something more sinister going on.
Bedroom PC - Lian-Li O11 XL Evo - Intel Core i5 13600k @ 5.4P / 4.4EGhz -  MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - Gigabyte RTX 4090 - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Living Room PC - Hyte Y60 - Intel Core i9 9900k @ 5Ghz -  MSI Meg Ace Z390 Mobo - 16GB Ram - Palit RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i7 8086k @ 5.1Ghz -  Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA RTX 2080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office - Thermaltake Tower 100 - Intel Core i7 8700K @ 5.1Ghz - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA GTX 1080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Annex - Corsair 250D - Intel Core i7 3770k - Asus P8Z77 I Delux Mobo - 16GB Ram - EVGA GTX 980ti - 256GB Corsair SSD - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Office - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 15TB Storage Server
Living Room AV Setup 5.1.4 - Yamaha RX-A2060 - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Yamaha RX-A1070 - 5 x Monitor Audio C265s (2 Zones)
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
1 hour ago, ChrisLoudon said:
Hi buddy,
Hi Chris,
That would be my last option. But I'm not savvy enough format it on my own. I try to do simple fix but if that not enough than I'd have no choice but to go to the computer store and get it formatted.
1 hour ago, M.SR said:
Hi Chris,
Hi buddy,
from your first post it looks like you've covered pretty much all of your bases apart from a fresh install.
Its pretty easy.
1. get a USB hard disk / pen drive with at least 8GB of space and pop it in your PC.
2. Search 'Windows USB Tool' in Google and click what will likely be the top hit to take you to MSs website.
3. Download the tool and run it. It will scan your PC and download the correct version on Windows and create a bootable USB drive.
4. With the USB stick still plugged into your PC, reboot and make sure the PC is set to 'boot from USB'. This will likely be displayed briefly on system start-up and is usually an F key.
5. When successfully booted from the USB media, you'll be asked if you want to do an upgrade or a 'custom install' Select 'custom install' and when you're asked about what drive and what partition, delete ALL partitions (on the main drive - usually drive 0) and then your pretty much good to go.
During the installation process you'll be asked to login with your MS account, select a network and keyboard and language stuff but pretty straight forward.
The only additional things you might need to to once Windows is back up and running is download drivers, tools, applications and games. You'll also need to make sure your files are backup up on OneDrive or Google Drive so you don't loose anything.
Cheers
17 minutes ago, ChrisLoudon said:
Hi buddy,
Its pretty easy.
Cheers
Chris,
Dang. I don't expect a full-blown step by step guide on how to fresh install a Window software. Thank you so much. As of now, I tried installing Malwarebytes to scan for malwares and it did find 2 threats. I've removed the threats and currently monitoring the performance. If all else fails, I'll try a fresh install the Window.
My laptop is running the original edition of Window since I first bought my laptop. Does the Window from Window's website require any new license purchasing or it will detect the original license from my laptop and downloaded it free?
Hi buddy, no worries.
Windows licenses and activation are now usually tied to your Microsoft account so its pretty straight forward.
When the USB media is created and you boot from it, it either just goes straight to the correct Windows Version or it will give you a list to chose from. You'll just select Windows 11 Home and you'll be good to go.
If you have a product key (usually found on a sticker on your PC) you can type in when prompted however, if you can't find one, most of the time time you can click the button 'don't have a product key' and once you first login after the fresh install, Windows will link your Microsoft account to the last activation state and you should be up and running.
The only caveat to what's called 'Digital Licenses' is if you make and significant changes to your hardware, Windows won't automatically reactivate and you need to jump through a few hoops but since this is a laptop I doubt you'll run into this issue.
Chris,
I think I might find what's causing the issue here. It might be some rogue software running in the background.
When the laptop slowed and I tried to shut down the PC when some program is running, there's ONE program that pop-up without any name that Windows trying to close during shutting down. Also, sometimes when I use my PC, there a program popup but it immediately gone before I can identify what the program is.
I tried scanning my PC with Windows Defender, McAfee and Malwarebyte. Before my previous reset, Malwarebyte found 1 threat in C:\Users\MyPC\MyPC\zkavia.exe . I deleted the file trough Malwarebyte and did another reset.
I know PC Reset is not like formatting a PC. But now I'm restricting my installs on some basic app and it's running smoothly. At least for now.
It might take a few days to test this out. But I have saved your instructions on formatting the PC in a Text Document for me to refer later on. It's good to know that the licenses are tied to my Microsoft Account. I always avoided formatting my laptop due to not wanting to lose the original licenses on Windows & Office. But now I know that concern is baseless.
I really appreciate your reply regarding my issue. Thank you. I'm new here so it's good to see that this community does help each other out.
