A really solid build, you don't NEED a 360mm AIO, it would work just fine with a 120se/ak620, but if you got it because of the looks, then it's perfectly fine. It's also a good idea to get the am5 contact frame from thermalright, those cost like 15$, but can reduce the temperature quite a bit, and prevent possible bending, tho it's unlikely with am5 cpus, because they don't get hot enough
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16366922
its 240mm but i picked it because i want my build to look good
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16366924
get 7600 instead of 7600X (if X is more expensive)
current PC:
PC configs I used before:
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16366930
2 minutes ago, Patss said:
the 7600 is 6$ less should i change it or keep the X version?
keep X, 6$ is not that much
I'd get a better SSD though, is your budget already exceeded?
I could propose some cheaper parts that get the job done either way
current PC:
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16366936
27 minutes ago, Patss said:
After a ton of research and watching youtube videos I made my first build! Going for a black/grey build so it matches my peripherals/setup. My budget is 1300$ and yeah let me know what you think about it!!
https://pcpartpicker.com/list/2XjJDZ
Those prices aren't matching up on PC Partpicker such as that MSI board that's going for over $200 USD atm.
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16366939
36 minutes ago, Patss said:
Sure i could go up to 1350$ for the drive
for the parts prices, are you buying used, or with deal, or from Microcenter or something?
current PC:
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16366954
Just for a thought, this CPU cooler is 30-40$ and it has enough power to cool 7800x3D from AMD, the Motherboard is cheaper but good quality, only 2 M.2 slots but for the price it's worth it, there could be another MB with 3 M.2 slots within 10$ of it maybe, and the SSD is the cheapest Nvme that has good speed and quality, at least on US pcpartpicker:
PCPartPicker Part List
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($180.99)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($159.00 @ MSI)
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($115.70)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Video Card: Sapphire NITRO+ Radeon RX 7800 XT 16 GB Video Card  ($508.26)
Case: NZXT H5 Flow RGB ATX Mid Tower Case  ($103.31)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.17)
Total: $1282.31
Generated by PCPartPicker 2024-03-29 18:07 EDT-0400
current PC:
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16366957
1 hour ago, Patss said:
I can get them without taxes and i also dont live in the USA
Which region? You can switch PCPartpicker to your region and then you'll get a better idea of prices as some parts are heavily discounted (or more expensive) in certain regions - saves people choosing one part over another similar one due to price, but the choice would be different based on where you will be buying this stuff.
Main rig: Ryzen 7 7800X3D, RTX3080Ti FE, 32Gb Teamgroup Create-T DDR5-6000C30, AC Freezer3 280mm AIO, Asrock Steel Legend X670E, M.2 2Tb Samsung 990 Pro, M.2 1Tb WDSN550, SATA 8Tb WD80EFAX, Corsair HX850, LianLi O11 Air Mini + 3x NF-A14's, MSI MPG 271QRX (27"/1440P/360Hz), Gigabyte M27Q (27"/1440P/170Hz), Asus PA248 (24"/1200P/60Hz), G815 kbd, G Pro X Superlight 2, Audezee Maxwell.
Games room "TV rig": 5800X3D, AC Freezer2 280mm AIO, ASUS Prime B450M, RTX4080S w/iChill AIO, 32Gb TridentZ DDR4-3600C14, M.2 500Gb & 1Tb WDSN550, 8Tb WD80EFAX, BeQuiet Straight 1000W,  LianLi O11 Air Mini, LG G4 (55"/4K/120Hz), G815 kbd, G502 mouse, LG G1 Soundbar / Audezee Maxwell.
Lounge HTPC: Minisforum UM760 Slim, Ryzen 5 7640HS, 16Gb DDR5, 1Tb M.2, LG C2 (42"/4K/120Hz), Logitech Touch K400.
Laptop: LOQ16, RTX4060, 16Gb DDR5, 2x 2Tb SN990 M.2.
NAS: Synology 1812+, 3Gb RAM, 3x16Tb Seagate EXOS RAID5, 1Tb MX500 cache, 3x3Tb WDRED RAID6, 120Gb SSD cache.
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16366986
Europe, my country isnt listed but the closest would be finland
https://linustechtips.com/topic/1564754-first-build-1300/#findComment-16367207
