STUCK AT 2133 :(
4 minutes ago, YoLige said:Installed new set of RAM (G.Skill Trident Z Neo 3600 Cl16 2x16Gb) and have enabled XMP profile on my mobo/bios, then checked task manager and its still running at 2133.
Not sure if task manager is a valid way to check speed and if I'm even setting my Ram speeds correctly, but id like to use it to its specified capabilities.
RAM is installed in slots 1 and 3, not sure if that's any use.
Lemme know if I'm being dumb or if you've got any fix to this please, in need of assistance!Thanks heaps!
My pc parts list below -
Yes install ram in slot 2 and 4 (A2 B2), if you read the manual, that's the config in dual channel mode. Enable XMP again. If it doesn't post for some reason after you've moved the ram, clear cmos
