16 minutes ago, koopa990 said:
<img>
thats just a cherry mx compatable key cap
depending on which one, you can get a cheap set of some caps or you may have to buy a full set of letter caps but you should be in it less than a whole keyboard and you have opportunity to customize and stylize your keyboard.
or if you just want it to work, you can prise off a cap you dont ever use like scroll lock and put it in the place of the broken one, they are very universal
https://linustechtips.com/topic/1563220-1-keycap-shell-broke/#findComment-16355443
Hm I see...
Well. I suppose substituting another keycap should do for the time being.
https://linustechtips.com/topic/1563220-1-keycap-shell-broke/#findComment-16355453
