Fans stay at speed after temps fall
8 hours ago, W0lv said:Recently, I've had a problem with my fans staying at higher RPMs (and therefore louder) even after temps fall back down to idle. Basically whenever I play a game or set a render, fans will increase along the curve I've set for the CPU temps, but when I stop and let my computer sit, temps will go back down naturally with little to no load but the fans stay at the speed they got to until I restart or put my computer to sleep, and they'll fall back down to normal. GPU fans will go down like normal, just not my case/rad fans
It's honestly not that big of a deal, but its annoying so any advice would be very appreciated!
Computer Specs in case they help:
Asus ROG STRIX B550-F Gaming WIFI 2
Ryzen 5 5600G
Corsair iCue H150i Elite LCD AIO
2 Noctua NF-P14s redux 140mm Intake
3 Noctua NF-P12 redux 120mm Exhaust through AIO
32 GB 3600 Mhz Corsair Vengeance RAM
XFX Radeon 6900XT
all in a Lian Li O11 Dynamic EVO
Are you using Armoury Crate (AAC)? If so, are you using Fan Xpert? If yes, which version? If you haven't upgraded it to the newest version, try that first.
If that doesn't work, try closing AAC and make sure it's not still running (check your systray by the clock, and task manager). Also, check task Mgr for MotherboardFanControl and end task on it. If that helps, go into Fan Xpert and disable its ability to control the fans.
If that doesn't help, download the AAC clean uninstall and let it get rid of everything, especially AI Suite and Fan Xpert, and settings.
Reinstall AAC. Don't use AI Suite because it requires that you turn off a security feature that can leave your PC vulnerable. Do not use the auto-tuning feature in Fan Xpert, just set the curve in FX manually or in BIOS.
